Generation IV External Engine - Swapping LS3 into 4th GEN SS
Sweet_SS
06-29-2012, 02:27 PM
Curious as to what throttle body I can use with the LS3 intake. I know the stock LS3's are "drive-by wire" rather than a cable. Can I use an LS2 throttle body?
Thanks.
sssalah
07-01-2012, 12:53 PM
LS2 are fly by wire. I used Edelbrock 92 mm which came with the IAC and TPS.
babbage1109
07-01-2012, 12:58 PM
Couldn't you just use a nw or any other 90 mil throttle body. As long as its cable driven
Sweet_SS
07-01-2012, 09:25 PM
Thanks fellas, I will look into those
Sweet_SS
07-01-2012, 09:27 PM
Thanks fellas. I will look into those.
4U2NV-SS
07-17-2012, 08:59 AM
I just used a cable driven PTM 102mm TB.
1lejohn
07-17-2012, 08:29 PM
Any cable driven 90mm T body will work. I recommend that you clean up the entrance of the stock manifold. Mine had a lip and some rough ridges.
jsmith564
07-17-2012, 09:06 PM
true story
Sales2@Texas-speed
07-18-2012, 10:44 AM
Just keep in mind you'll need to fabricate a bracket to hold that little plastic piece so you can adjust and hold your throttle cable in place....there was no such provision on the LS3 intake!
Sweet_SS
07-25-2012, 09:30 AM
Motor is in via
www.Premierperformanceut.com
Premier built and installed the motor
http://i46.tinypic.com/28itbv7.jpg
-6.0 block
- L92 heads
- LS3 Crank
- LS3 Intake
-Manley I beam rods
-JE Pistons and the list goes on.
It should be on the dyno this week, but I'm not to sure I have the fuel system for the power I'm looking for. I have a single Walbro 255 and 60lb injectors. I'm hoping for around 650RWHP out of my TC78.
sssalah
07-25-2012, 01:56 PM
Highly doubt that your walbro is sufficient to feed this power level, maybe dual in tank setup or one external large aeromotive is what you require.
Sweet_SS
07-25-2012, 02:04 PM
That's what I was thinking as well.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
