Worth it to port heads while doing gaskets?
After a couple set backs with working on my car, I've got the heads off now and am about to have a friend check them at his machine shop. Right now I just plan on getting the car up and running, but since the heads are off now would it be okay to get them ported? Or would I need a good tune if I did that? I do plan on getting a cc305 in the near future so I know I'll need a tune for that of course but I wasnt sure about just ported heads
Worth it? Only in professional lt1 experienced hands,So.. Yes. But even more so with Springs and a power tune .. Ditch that hypertech .. I can believe you put it in your sig ...
Well when I made the signature I didn't know they were worthless. I just got into the camaro world..and it came with the car when I bought it. So why not? And that's true. I may wait. But what would you recommend besides the cc305? It'll be a daily driven car so I don't want anything so aggressive that it wouldn't be healthy for everyday use.
I mean I know a custom grind cam would be best paired with some heads from AI or LE but that isn't in my price range right now. I just figured a 305 wouldn't be aggressive as a 306 and would be a lot better than stock for me right now
scroll through summit and check them out. stock cam specs are 206/214 I THINK. If not thats pretty close. So just go from there and see which one suits you best. Id rercommend something around 226/230
good luck!
good luck!
Thanks! Well I just looked through summit and the cams they have under Advertised Duration go from 207/196 to 236/246 and all the way up to 346/346 but nothing between those first two. Should I be looking in the Duration at 050 inch lift catagory?
get out of the catalog and hit one of these websites
http://www.advancedinduction.com/LTX/AiLTxMain.php
http://www.elliottsportworks.com/
No nitrous. The motor has 184,000 on it lol I was going to rebuild the bottom end but for now I'm just doing head gaskets to get the car on the road. And if I need to I can just save up for a stall so I'm not realy concerned with what one will cost. I'll be able to afford one eventually.
