what gaskets do i need with cam install
Old 04-01-2004, 12:40 PM
steelsnow's Avatar
Default what gaskets do i need with cam install
im going to have my cam installed in a little more than a week and i wanna make sure i got everything. i was informed today that i need gaskets. does anyone have the gm part numbers for this stuff? thanks for the help.
Old 04-01-2004, 12:44 PM
10 Second Club + 14 Second Truck Club
antz01ta's Avatar
scoggin dickey (sdpc2000.com) sells a cam change gasket kit.
Old 04-01-2004, 12:59 PM
steelsnow's Avatar
sweet!! thanks man. thats a life saver. its even got the freekin bolt for the pully!
Old 04-01-2004, 01:45 PM
horist's Avatar
all you'll need is a new crank bolt, and a new front main seal .... timing cover gasket, valve cover gaskets, etc.. are all reusable (some have even reused the front main seal but i'd advise against)
what's the kit come with? When I did my heads/cam I got a complete kit... and found out afterwards Most of the gaskets are reusable for 99+ cars... so no sense wasting money if you don't have to...
Old 04-01-2004, 02:02 PM
steelsnow's Avatar
---Camshaft installation kits include intake valve cover gaskets, timing cover gasket, water pump gaskets, front cover gasket, front cover seal and a new balancer bolt.---
http://www.sdpc2000.com/cart.asp?act...721&pid=123618
i went ahead and got it. the gaskets being reusable is cool, but new is better. you cant go wrong i guess. i got my *** covered now just incase.
Old 04-01-2004, 02:20 PM
antz01ta's Avatar
