12 Second Club - Bye Bye 12's
96SOM383
06-30-2012, 01:54 AM
So after breaking a valve spring I went another way with the car. Installed a custom grind cam 228/230 588 591 112 lsa +4. Also went with 5.3 heads for the higher compression. Hoping for the best time result's coming soon will keep posted !
superGTO
07-01-2012, 09:00 AM
Wow, that should easily do 11s. Waiting to see results......
96SOM383
07-08-2012, 11:18 PM
Still on time results yet! Been working alot but damndoes she pull hard ....
96SOM383
07-15-2012, 10:38 PM
Okay so I made it to the track Friday night, not that great of a night... I put the Skinnies on the front and to my suprise first pass it pulled the left front wheel HELL YEAH !
I went a 12.17 @ 112mph with a 1.75 60ft. Not to bad seeing as how I was going 12.60's....
2nd pass went 12.18 with the same mph and 60ft....
3rd pass is when all hell broke loose. I zinged the converter shifting into 3rd so I shut her down. The drive home sucked, the tranny was getting hot the converter was shot annd wouldnt lock @ 50mph. So I pulled the converter today, tranny fluid was not burnt at all.....
BUT- I dumped out all the fluid from the Yank SS 3600 Stall to find that its broke and shit it ratteling around..... I just dont understand how my little ole cam only car put a beating on this converter so easy seeing as in under power'd for its 650hp rating lol... So Im sending it off to Circle D to have it fixed and done up righ..... More times to come onceshe is back together ...... Damn I can almost see the 11 second time slip in my hand....
senicalj4579
07-17-2012, 01:33 PM
good times but that sucks about the tc
Kingc8r
07-17-2012, 01:39 PM
How much does Circle D charge to restall/fix your Yank converter?
96SOM383
07-18-2012, 10:37 PM
Didnt restall kept it 3600 but with new upgraded/stronger parts.... $300
B18B1LS1
07-19-2012, 06:06 PM
What did Yank say about it?
96SOM383
07-19-2012, 08:08 PM
Did not talk to yank, I bought the converter used and when it broke I just went with Circle D cause they are local and very well known !
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
