Drag Racing Results - alittle more mph..
View Full Version : alittle more mph..
350znal
06-30-2012, 08:18 AM
Previous best slip was at -3 da. Temp was 55 degrees and 21% humidity mods: k&n intake, ported tb and weight reduction.
60ft:1.979
330ft: 5.456
1/8: 8.329
mph: 86.83
1/4: 12.845
mph: 108.97
Tonight it was 80 degrees and 61% humidity.. Da was 2335
Mods: K&N intake, ported tb, weight reduction(still at 3800lbs with driver), long tubes, catless mids, spintech catback and a hp tune(loaded from the repository). Also alittel slip from the clutch, but no biggie for now.
60ft: 2.101
330ft: 5.626
1/8: 8.493
mph: 87.13
1/4: 12.973
mph: 110.15
Da correction for that time would be around 12.5@113... I need better weather. LOL
T6Rocket
07-03-2012, 01:09 PM
Too hot to be racing for anything but competition, where everyone is on an even playing field. Personal bests are not going to fall in this heat.
Al
Doug G
07-03-2012, 03:37 PM
Always made best passes in eary spring/late fall....hell with all this 90*+ heat and high humidity....no shade and all asphalt http://ts2.mm.bing.net/th?id=I4571585298628845&pid=1.7&w=166&h=149&c=7&rs=1
350znal
07-04-2012, 08:18 AM
Yeah, i know no pb's will happen.. I am suprised i gained mph, but with different mods and tune now i should have. I know it will be better in the fall..
nocooler
07-04-2012, 07:01 PM
More mph on a worse 60' - if you would have gotten the 60' back to a 1.9 - it would have went faster.
Ditch the repository tune and retune it yourself ;)
350znal
07-04-2012, 08:27 PM
The clutch didn't hold the launch is why it was a 2.1. It gave alittle( stocker with 74k miles). The tune is pretty damn close. Going to put it on a dyno and wideband to find out whay needs to be adjusted from here.
Goal is to see high 11's low 12's around 112-114 traps with bolt ons only.
