New LS1 Owners - Newbie Tech - Rearend question
redcamaro4140
06-30-2012, 09:55 AM
Hi my questions is I have a 99 v6 Camaro I put a 99 ls1 rearend in it that rearend had no abs on it. So I'm asking If I keep my abs wire plug in and just zip tie it up and out the way will it hurt anything please I need to know soon I want to take off jake stands Thanks
combs_425
06-30-2012, 10:58 PM
no but you will not have abs. you will also get a dtc. Im pretty sure that you can turn it off with hp tuners.
redcamaro4140
06-30-2012, 11:54 PM
I all ready did the delete check I just wanted to make sure plug in abs wire and just zip tie up how the way if it would hurt anything it's my girl Camaro
caturnbull1
07-01-2012, 12:05 AM
you should be fine. i had a wire off on my abs a light came on saying inop but everything else worked fine just no abs till i pluged it back in
redcamaro4140
07-01-2012, 12:18 AM
Ya I want the abs wire plug in so my tcs light switch lights up
caturnbull1
07-01-2012, 12:20 AM
the light on the switch will still work. i had a wire unpluged on my rear axle. but on the dash the inop light will be on as well
redcamaro4140
07-01-2012, 11:23 AM
I know the dash will say inop but I broke the light in cluster so they won't be on so tell me I'll be okay with the abs wire plug in and zip tie up out the way yes or no
bpittman
07-01-2012, 05:42 PM
Having it plugged in or not doesn't really matter, either way it's(abs) not going to work. Zip tie the connector out of the way and call it a day if you don't care about abs working.
redcamaro4140
07-01-2012, 06:06 PM
Sweet that's what I did because I don't care if the abs works or not
caturnbull1
07-01-2012, 07:09 PM
yes your good to go
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
