Gears & Axles - e-brake brackets
oldmano2z
06-30-2012, 11:11 AM
i know it's been covered can anyone tell me how or where i can find info on cutting the e- brake bracket to fit my S60 with the bmr lca brackets?? please!! it's a 108 degrees here in Mo. and this old man is getting sweaty! i was hoping that i'd never smell like a sweaty oldman but.... you know like granpa. pics would be nice but i have an imagination thanks the oldman........
BlackLS1Bird
06-30-2012, 12:17 PM
I will have to take some pics of mine. The bracket is a 3 sided box design. I cut off the back and inner side, leaving only the outer side where the cable goes through the bracket. Using the factory bolt hole, just place it on the same bolt as your LCA. Works great.
oldmano2z
06-30-2012, 05:20 PM
thanks blackls1bird, i kinda thought that. i'm thinking of keeping the back also and cutting off just the side opposite the cable and line bracket ,then drilling a hole in the back of plate and adding bolt back there thanks for your info... the oldman...........
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
