fbodieslive
06-30-2012, 02:09 PM
Alright a may try to sell my bird in a few months, but before I do I wanted to try and fix everything thats wrong with it. Alright for starters its an 02 ws6 A4 with no mods. It's got 117,000miles on it. When I got it 2 years ago it didn't have any SES lights on. After about a year of driving it I got an SES light. Scanned it with a hand held, got two codes. PO171 and PO174 (bank 1 system to lean) (bank 2 system to lean). A little farther down the time line it started making an awful racket underneath the passenger door. I got under it and found it to be coming for the catalytic converter(just the passenger side). Took it off and the cat had come apart inside and was rattling around. It's my DD, so I just busted it all out to stop the rattle. I guess my question is could the cat have been causing my codes before it came loose? Are my oxygen sensors done for with no cat in place?
2nd issue: This may be related to the above. Sometimes (its inconsistent sometimes it does it sometimes not)when I come to a stop like a red light and then try to take off the car will shutter for a second like it doesn't want to go. If I give it more gas it will suddenly lurch forward. Like I said it only happens sometimes and it only does it when I come to a stop or almost a stop.
3rd issue: This has just happened in the past month or so. Ill be riding along and all the sudden some of my dash lights will come on. The TCS light comes on and my button for TCS won't work. The ABS light comes on as well. It's happening just about everytime i get in the car. I'll Get 20 miles down the road and they will pop up. If I turn it off and then back on they all go away.
4th issue:My suspension is getting really squeaky. Anyway to fix that.
One more thing how do you get the change oil light to go away. It was in my manual, but I can't find my manual.
Thanks, in advance.
Thanks, in advance.
