shippershack
07-01-2012, 12:31 PM
Hey guys,
To you I come for advice again. I'm about twelve hours into the install of the Pioneers avh4400 in my 2002 Trans Am. I used all the info on this site to get it going. I am having trouble getting the head unit to sit level, as the bottom tray is getting in the way and i can't get the power antenna to work. I trimmed the top, installed the Metra axxess awsc steering control unit, and the parking brake override kit. The tilt on the unit is preventing DDmods faceplate to fit right and allow the unit's faceplate to open and close correctly.
So for the fitment, did you guys all remove the whole plastic base tray? Is that enough to support the unit or should i make some longer brackets than the one DDmods supplies? By the way, Dennis from DDmods is a great guy and stands by his product when you buy it.
for the antenna, The thick dark Blue wire from the Pioneer should connect to the thick light pink of the GM harness...right? I tried it, but it didn't work. Maybe I didn't securely attach it? What is the proper way to connect the blue and pink. Can I simply yank out the pink from the GM harness and twist cap it off to the end of the blue? What about the orange wire from the Pioneer harness...it says illumination on it, but there was no place to hook it up to the GM harness. Does this have anything to do with the antenna?
I'm frustrated as he'll...help is appreciated, you're advice rocks,
Rob
Rob
