Dynamometer Results & Comparisons - 402 low numbers?
View Full Version : 402 low numbers?
99slobird
07-01-2012, 12:31 PM
Just looking for what y'all thought on my setup and what it made. Car Is a 99 Ta th350 4500 stall and a 12 moser 12 bolt 3.73 gear Motor was actually built for boost (about 9.1cr) but was told it worked well on nitrous too. West coast cylinder heads port matched 102/102 238/244 .620 lift 1 7/8 headers 3 inch x-pipe On motor car made 457/449 and it has a stand alone and a direct port kit on a .30 jet on nitrous side it made 646hp at 5600 rpm before the car raised above whatever it is that reads rpms off the crank pulley Haven't taken it to the track yet just wondering what y'all thought
djfury05
07-01-2012, 12:37 PM
Seems fine to me with the drivetrain selection
99slobird
07-01-2012, 12:43 PM
I ment to put that it is a sd tune. The Dyno room was 108.5 degrees and 30 percent humidity
Sprayed1998
07-01-2012, 01:07 PM
TH350+12 Bolt+low comp
venom ws7
07-01-2012, 03:19 PM
Those are awesome numbers in my opinion...
Low comp and power robbing drivetrain was the converter locked?
odarabla
07-01-2012, 06:26 PM
I have a Ls2 402ci motor as well th350 with a 8" 4000 stall, strange 12 bolt rear end.. .. I dynoed the other day @455rwhp to the tires. But have run a 10.39@129mph 1.41 60ft.. on motor so far.. I made 575rwhp with a 150 shot.. Looking for high mid 9's on the spray..
99slobird
07-01-2012, 06:38 PM
Well I'm just wondering if I gained anything by going 402. I sold my 383 that made 440 on motor and 663 on a 225 shot for this motor. And it ran 7.0s on motor and 6.1 on spray. 1/8 mile
99slobird
07-01-2012, 06:50 PM
CustomX
07-01-2012, 08:35 PM
Only one way to find out for sure! Get it to the track!
odarabla
07-02-2012, 05:45 AM
I normally run 1/4 but my car runs 6.6@103-104mph in the 1/8th on motor with a 1.4 60ft.
99slobird
07-02-2012, 10:10 PM
I checked my convertor last night and it foot braked 4700 in the driveway lol. Holding the trans brake it went over 5grand lol. Convertor is wayy to big.
SMOKINV8
07-02-2012, 10:35 PM
Have you compared the area under the curve? You're just quoting peak numbers.
I'm with the guys above though, I think the numbers are pretty good for the package.
odarabla
07-03-2012, 11:44 AM
My first time to the track I had a 5000rpm stall with the th350 and ran a 10.39@129mph 6.6@104mph in the 1/8th with a 1.41 60ft.. Run it before you pull it..
