Carbureted LSX forum - Could this pinched O-ring on the oil pump pick up have caused a spun rod bearing?
tommy396
07-01-2012, 07:04 PM
While I was getting ready to put the engine back together I noticed the 0-ring had been pinched while it was put together before, not that it will fix anything, but I'm wondering if anybody thinks this may have been a contributing factor to the spun rod bearing? I was idling between 25 & 30 psi of oil pressure & most people I'v spoken with seem to think that oil pressure is what spins rod bearings. I posted some pics & was wondering what everyone else thinks?
http://i1250.photobucket.com/albums/hh536/tommy3961/2012-07-01_15-07-32_324.jpg
http://i1250.photobucket.com/albums/hh536/tommy3961/2012-07-01_15-07-00_550.jpg
http://i1250.photobucket.com/albums/hh536/tommy3961/2012-07-01_15-08-05_531.jpg
Doug G
07-01-2012, 07:24 PM
The LQ4 I bought had no oil pressure...I had no clue why. New OP and still nothing.(done before I bought)
When I tore it down I found #3 cam bearing wiped....both the rods and mains looked factory fresh as well as the cylinders.
I'm sure the bottom end had good OP but was lost at the cam bearing.
IF that pinched O-ring was allowing air to get in....sure couldn't have helped.
ZONES89RS
07-01-2012, 07:28 PM
It is possible.
tommy396
07-02-2012, 03:52 PM
I'll definitely be really careful when installing the new one!
lemons12
07-02-2012, 03:55 PM
Oil pressure is almost always what cause a spun bearing in Ls1s..
snook
07-02-2012, 06:12 PM
They make a girdle for them, why gm just used 1 bolt is beyond me. I used one on my 5.3, made me feel better anyway...They are on ebay too
http://www.brphotrods.com/mm5/merchant.mvc?Screen=PROD&Store_Code=BRP&Product_Code=LS1-G&Category_Code=CNV12
A pic explaining
http://www.brphotrods.com/installguides/LH8OP.pdf
Some of the early truck tube girdles had a huge tack weld keeping you from using this girdle, so It may not work with early truck tubes is why brp says it wont work with truck version. Worked fine for my 04 5.3 though....
S10xGN
07-02-2012, 08:17 PM
Quite possible. Even with fair to good oil pressure showing, it'll be frothy with air bubbles which do not help at all with lubrication.
tommy396
07-02-2012, 09:35 PM
Hey Snook, that thing looks pretty cool, but I couldnt find one locally, do you know if they have dealers? If not, I'll probably weld another ear on the opposite side, or just make a girdle. Either way, thanks for the info..good stuff!
ZONES89RS
07-03-2012, 12:50 AM
I never worry about the factory tube setup. Have not had failure yet and I have done more swaps than most. If I was spinning above 7500 I would consider that little double mount.
LS1MCSS
07-03-2012, 06:59 AM
I think you'll have to buy it direct from BRP.
snook
07-03-2012, 05:06 PM
Yeah, straight from brp. They did have them on the ebay brp website, but not on there now. Its probably not needed, just reassurance though. Maybe put a dab of oil on the new oring too, so it seats easier.
