New LS1 Owners - Newbie Tech - Need Advice, What would you do?
View Full Version : Need Advice, What would you do?
2BASOMTAS
07-01-2012, 10:44 PM
I just bought a 2002 Pontiac Firehawk, It has a cracked Block, my delima is should I try to fix it (if it can be fixed) and keep it original? it is 1 of 11 built, or should I try to find a different motor, I am new to this and dont know much about them, What is the Difference between the LS1 in a WS6 verses the LS1 in a Firehawk?:confused:
StuntmanMike
07-02-2012, 12:03 AM
AFAIK, to keep it "matching numbers", you'll just need a replacement block from 2002. If the block is cracked, I doubt it can be repaired. Even if it could, not sure I'd want to be driving that car afterwards.
And a LS1 is a LS1 is a LS1. No difference between any of the LS1's for any given year. The engine in your Firehawk is the same engine you'd find in a '02 Formula, T/A, or WS6 T/A. The Firehawk may have a different hood, airbox, and maybe cat-back, but the actual engine itself is the same exact engine you'd find in any '02 LS1 F-body.
sepsis
07-02-2012, 01:30 AM
Just get a short block, you'll be fine and nobody will ever know.
bww3588
07-02-2012, 02:09 AM
To keep it "numbers matching" you would have to keep and fix the existing block...no way around it.
As far as that, an ls1 is an ls1 but there are differences between years. However, each difference cancels out the next, so power wise, yes, they are relatively the same, but there are year specific differences.
RPM WS6
07-02-2012, 11:06 AM
:nod:
'02 LS1 is the same from a Z28 to a Firehawk to a Formula to an SS. There is nothing specific about the actual engine that is at all dependent on trim level.
zeeman99
07-02-2012, 01:49 PM
Get a new short block and fix it correctly. Keep the original block in storage and it will be there down the road if someone wanted to try and repair it to be matching numbers.
2BASOMTAS
07-02-2012, 07:23 PM
Thanks to all the replied, I appreciate it, Okay now does anyone have a 2002 LS1 motor forsale??
Mean87SS
07-02-2012, 08:10 PM
What makes it 1 of 11?
2BASOMTAS
07-02-2012, 10:18 PM
only 11 Firehawks were painted sunset orange, convertable, with a manual
I8UR4RD
07-10-2012, 09:45 PM
5.3's are going cheap these days and holding more power, but as stated, as far as keeping it matching.....i wanted to do the same thing....but you cant fix certain things IMO.....
http://i262.photobucket.com/albums/ii107/kief4diamonds/cracked-1.jpg
hotrodth
07-10-2012, 10:27 PM
Just have it resleaved
I8UR4RD
07-10-2012, 10:35 PM
yeah, thats what I thought i was going to do, till i saw where the rod went thru the damn thing.
