LQ9 Buget setup 415-430whp
Old 07-02-2012, 04:15 AM
smileyou's Avatar
Default LQ9 Buget setup 415-430whp
I spun a bearing in the ls1. So, I am swapping in a lq9... Im wondering if my setup of lt's, true duals, ls6 intake, lid, and either a pat g custom grind cam in the low 230's, a 288r or the torquer v3 will get me past 400.
I will be reusing the 2001 241 stock heads... Will my CR be an issue? What am I looking at for hp? I plan on switching to ported heads or 243's castings down the road...... any advice for me? I will be performing the swap for the first time in my garage.
...Or should I just rebuild my by returning the crank and replacing the bearings seals ect.. Is it even worth it paying for all the labor and maching?
Old 07-02-2012, 05:58 AM
bww3588's Avatar
I'd either just run the 6.0 stock until you have the time/money to do the heads and cam once. Then get a custom cam to match everything.
Old 07-02-2012, 07:12 AM
mark21742's Avatar
You should get close to your goal. Check your ptv clearance and possibly mill a little off the 241's before you bolt them on. You will need a 6.0 head gasket and I would recomend a .040" mls gasket to keep your quench nice and tight.
The 241 heads aren't that bad of a head with some work done to them.
Old 07-02-2012, 07:32 AM
ss454327's Avatar
The LQ9 doesn't have heads on it? I would drop the coin on a set of stock 243s or 317s instead of the 241s. 317 heads can be had CHEAP so there is no excuse there. Also I would say for cam run the TQv2 or an MS3. The 6.0 likes a healthier cam than the LS1s do IMO. As for your power goals an LQ9 is really close to an LS2 in power so 400 rwhp should be easy with a nice size cam.
Old 07-02-2012, 09:21 AM
smileyou's Avatar
How much should I get milled off of the heads? And I wont be able to do heads for a year or so... So i'd rather get the cam spec'd out for the setup now....rather than wait for a different set of heads. Reminder... this is a budget build. So Im trying to use as many parts off my ls1 as i can.
Also..If im buying a stock lq9 shortblock. Is there anything I have to do other than swap the accessories over and drill a extra alternator bracket hole?
Old 07-02-2012, 09:35 AM
ss454327's Avatar
There is nothing needed other than what you mentioned for the LQ9. It is a GenIII just like an LS1. Also I would do the 317 heads or find a long block LQ9. You will probably have an easier time finding a long block anyway.
Here is another suggestion. Find an aluminum block 5.3. They already have 243 heads and will be within 10hp of an LS1 mod for mod. There was a guy on the S10 forum that bought one for $550 with less than 100k miles. A 228R would wake one up nicely and down the road you can make a 383 out of it.
Old 07-02-2012, 01:48 PM
smileyou's Avatar
I think Im going to go for the lq9 from thompson motorsports for 1900$ ..a 12 month warranty and it should be nicely paired up with a low 230's cam and I plan to spray a 150 shot.
Old 07-04-2012, 01:24 PM
LS1 Racing's Avatar
5.3s are cheap, but the difference between an LS1 and even a 243-equipped 5.3 is going to be closer to 20 HP. The difference is 40 HP when you compare it to a 6.0.
I'd stick with the 6.0, but get your hands on some 317 heads and have them milled to get your compression back up. 317s can be had for $100 or less and a mill is pretty cheap. Or, as another poster said, pick up some 243s for around $300 and do the same. I did this (milled .026) on my 6.0 liter swap, through in a small cam and made the numbers in my sig.
Getting the big motor is the key, IMHO.
Old 07-04-2012, 03:45 PM
IRONFIST's Avatar
If you go find an LQ9 it'll already have 317 heads, but if you're looking for a 400+ ready built short block then you'll need a set of heads. You said you wanted a decent cam; take the money you were going to put towards cam / springs / pushrods and put it towards the best heads you can buy. If I could go back that's what I would have done. A cam would have been the last thing I did. Better heads will return you gains with zero compromise in driveability... You can always do a cam later.
The following users liked this post:
Homer_Simpson (11-29-2021)
Quick Reply: LQ9 Buget setup 415-430whp
