Cadillac CTS-V - Any vids on replacing front differential bushing?
FILE
07-02-2012, 12:26 PM
Is there any videos that illustrates this? Granted I rent the tool to take the bushing out from CS, how long does this take?
FuzzyLog1c
07-02-2012, 12:27 PM
That depends on whether or not you rent the tool. With the tool, you're looking at less than a hour. The differential block is the real PITA.
Edit: There are no videos.
furbe
07-03-2012, 03:10 AM
Here is one I found with a quick search. It's a Base Model CTS but the bushing is the same.
Replaced mine few months back same as this vid only on install I put the
creative steel bushing in the freezer for a couple days and it went in with
a few light hammer taps. No special tool or heat required.
http://youtu.be/Vvj3HJ9rMdc
BTW, The Creative steel diff "block" is a waste of money IMO. Think about it, If you install the creative steel bushing, the diff isn't going to move. That bushing is so solid it cant move.
BudRacing
07-03-2012, 10:38 AM
If you rent the press tool from CS, it comes with laminated, captioned 11x8.5" photographic instructions.
FILE
07-03-2012, 07:40 PM
Good to know..
