Junkyard 6.0's chime in please on your experience
Im curious of those who picked up junkyard motor 6.0's....... How do I know the rod bearings or cam bearings wont be smoked? If im mistaken a compression check or leakdown test wont be able to indicate those problems correct? Im not looking for more problems.. just bolt in and go with the 317's or 241's i already have.
What is helpful is if you can see the vehicle driveline parts come from.
If you see a vehicle that was mangled in a wreck then you know it was drivable when it's useful life ended. If you find a car in drivable condition in the boneyard then you have to question if it was drivetrain that sent it there.
