Preparing for a cam swap. Am I missing anything?
Old 07-03-2012, 01:03 AM
Decadence75's Avatar
Default Preparing for a cam swap. Am I missing anything?
I recently got a good deal on the GMPP Hot Cam from a friend that had it on a shelf collecting dust. I am getting things together for it's install and wanted to make sure I have everything needed before getting started. This is a list of what I have and other stuff I will be getting soon. Is there anything that I am missing? This will be on the stock 853 heads.
Parts I have:
GMPP "HOT" Cam - 12480033
Front cover gasket - 12558013
Cank seal - 12561244
Water pump gaskets x2 - 12559271
New crank bolt - 12557840
Valve cover gasket x2 - 12560696
LS6 spring seat x16 - 12565118
LS6 spring lock x16 - doesn't have a part # on them, 10166345 I think?
LS6 spring (Blue) x16 - 12565117
Parts I need to get:
Valve stem seal set (intake) - 12533586
Valve stem seal set (exhaust) - 12457652
Spring retainers x16 - 10166344
LS2 timing chain - 12586482
Ported LS6 oil pump and new o-ring
3 arm pulley puller
Valve spring compressor tool
Flywheel locking tool
KD tools 901 air hold fittings
KD tools 2992 air hold extension hose
5/16" dowels to hold the lifters
Is there anything other than the obvious fluids and sealants that needs to be added to the list? Thanks!
Old 07-03-2012, 01:09 AM
sweet99ss's Avatar
Looks about like my list. I will be getting the hot cam too. Any reason you are getting the ls6 spring seats, locks, and retainers? You can just reuse the stockers as far as I know. That would save you some money there
Old 07-03-2012, 01:10 AM
TransAmcoupe98's Avatar
Since you are already in there, I would check out a COMP Trunion upgrade for $130, cheap insurance. Everything else looks solid for the most part. With the exception of the tune...which I'm sure you already know.
Old 07-03-2012, 01:15 AM
The LS6 springs, seats and locks all came with the cam that I picked up from a friend. I am picking up the retainers to complete the package. If I am going to swap everything else might as well do the retainers while I am in there. My stock LS1 valve train has over 133K miles on it and I would just feel better making the swap. It's piece of mind.
I'll check that kit out. Thanks for the heads up on it.
Old 07-03-2012, 01:27 AM
sweet99ss's Avatar
Ok cool. I'm getting newer ones with my ls6 kit also I just thought i'd let you know
Old 07-03-2012, 10:02 AM
SStressin's Avatar
looks like you got all the good stuff.. maybe hardened pushrods you should get cheap insurance
Old 07-03-2012, 01:37 PM
It is my understanding that with a cam of such a mild nature that the stock rods are adequate.
Old 07-03-2012, 01:51 PM
redtan's Avatar
I would still upgrade them...again it's cheap insurance.
Old 07-03-2012, 02:00 PM
SStressin's Avatar
yea they are fine but you can get a set for i think 120 bucks pretty cheap for a piece of mind that you wont bend a pushrod
Old 07-04-2012, 01:55 AM
The Scammer Hammer
dr_whigham's Avatar
Chances are, at 133k miles, you already have a bent PR and just haven't discovered it.
Old 07-04-2012, 02:13 PM
Wouldn't there be some noticeable noise coming from the valve train if one was bent? I can't deny the wisdom and piece of mind that would come from replacing them, I was trying to do the swap on the cheap WS6store has a set of stock sized Manley chromemoly rods for $100 right now so I guess that I'll add that to my list.
Quick Reply: Preparing for a cam swap. Am I missing anything?
