Stereo & Electronics - led flasher issue
brandon9598
07-03-2012, 11:44 AM
I just bought new led turn signals for the front. They with with hazards but not by themselves. I know i need a new one but i am confused as to which one to get. And also i have no idea how or where to install it. Nobody has really clearly explained that. Please help.
WhiteBird00
07-03-2012, 01:45 PM
If you have no plans to replace the rear bulbs with LEDs then the EL-12 electronic flasher will work. It will compensate for the reduced current of a couple of LED bulbs in the front but it would not handle a complete LED conversion. For that you would need a special LED compatible flasher or a set of load balancing resistors.
The turn signal flasher is clipped behind the dash panel just to the right of the opening when you remove the knee panel under the steering column (above the OBD II port). Turn on a turn signal and follow the clicking noise to find it.
brandon9598
07-03-2012, 07:23 PM
Alright.. I need more help. I bought the Tridon el-12 flasher and IT DOES NOT WORK. Please tell me what to do next
WhiteBird00
07-03-2012, 08:12 PM
What happens? Does it not flash at all or does it flash too fast? Do the lights come on? Do your DRLs work?
brandon9598
07-03-2012, 08:35 PM
The turn signal bulbs come on for drls but not the tiny 194 bulbs. And they still do not flash, but they work with hazards still. And both the turn signal bulbs and 194 bulbs come on when i lock or unlock with the key fob
sjsingle1
07-04-2012, 03:18 AM
are your LEDs DRL compatible?
brandon9598
07-04-2012, 09:40 AM
I'm not exactly sure if they are. I know it's a 3157 bulb and that is the turn signal bulb correct?
WhiteBird00
07-04-2012, 01:08 PM
The 194 bulbs have nothing to do with turn signals or DRLs - they are parking light only.
The 3157 bulbs are dual "filament". They have a bright circuit for turn signals and DRLs and a dim circuit for parking lights. The two circuits are independent.
First try putting the original bulbs back and see if the signals work. That will tell you if the only problem is the new LEDs bulbs.
Also, DRL compatibility is a valid question. You should check that the bulbs you bought are DRL compatible (the ones sold by v-leds.com are not). While you're checking, make sure you didn't get 3156 bulbs by mistake (3156 is the single filament version of the 3157 bulb).
brandon9598
07-06-2012, 11:42 PM
okay. well what about the 3157 leds from superbrightleds? are those drl compatible? im not really sure haha. and also i read on another post that somebody plugged in two flashers to the stock harness? is there more than one flasher? because i only found one. and what do i need to do differently if i want to do a full led conversion? because i plan on doing one if i get this issue fixed.
sjsingle1
07-07-2012, 02:01 AM
i got my DRLs from superbrite.....their website will tell you if the bulbs you are looking for are compatible
brandon9598
07-08-2012, 01:28 AM
okay. well awesome. now that i have that sorted out.. what do i need to do a full led conversion? knowing that i already have the el-12, what else am i going to need? thanks!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
