quick.msp
07-03-2012, 12:30 PM
Hey guys,
Im new here I have a 87 fc3s with a 2002 ls1/t-56. Im having some issues with the motor starting and was hoping I could get some help!!
I recently relocated the abttery to the trunk, changed to a new dash, rebuilt the tranny and a few other things to the car. I gutted all the heater core and most of the useless sensors. When I went to put everything together, I turned the key and got nothing. I was getting 12 v to my starter, but the signal wire had 0 volts (even while cranking).
I then traced the signal wire from the starter motor and it went into the driver side fire wall into the car. It went to a plug with 2 terminals, One for the signal wire from starter, and the other went into the ignition. I jumped a wire connecting the two terminal and the starter worked.
Im trying to find out if this is ok to leave like this? shouldnt there be a Starter Relay?
The car is still not firing!! I still do not know why my fuel pump isn't coming on. Im also getting no spark to the engine. My battery is mounted in my trunk and I have my negative wire going to the chassis. Then I have my engine grounded on the firewall.
There are numerous plugs that go to nothing under the dash. All the heater assembly was removed. I dont know where I should be looking, the fuel pump worked fine before.
Thanks
Thanks
