xBrandonx
07-03-2012, 01:48 PM
I had to go get my registration re-newed (expired in March) so I can get my car inspected.
Got in my car at my house, primed the fuel pump twice, started up, ran great.
Stopped off to get gas. When I started it, it had little to no hesitation (5 min from my house).
Got to the DMV, circled and looked for a parking spot, parked it, went in, waited for the morons in front of me to finish (20 minutes later). Got my new tags and what not, left (30 minutes since I parked).
Got in the car again, primed the pump twice, started it....
It had some major hesitation while trying to start. It sounded like it was dieing. I put it into drive and it felt like the car was jumping. I pulled out of the parking spot and gave it gas and it would hesitate... so I just coasted to the stop sign to get to the bigger parking lot.
Once I got in the bigger parking lot I tried to just do laps around to see what was going on. It kept doing it... so I popped the hood, made sure the spark plug wires visibly looked ok, they did I guess lol. The temp was creeping up to 210, so I just blasted the heat on.
I looked under the car to see if anything was dripping, I didn't see anything but I heard rattling or cracking sound every now and then espically when I was circling the parking lot, it made crackling sounds.
I gave it some quick revs to see what would happen, if sounded like it wanted to die. After some revs, it was better. I pulled out onto the road and took the back roads home this time instead of the highway to be safer. It drove fine the rest of the way home.
There is no Check Engine Light on either.
This is not the first time this has happened. It only does it on hot starts. Any ideas? I smell fuel in the rear after I park the car; if that helps at all.
It only does this when you turn the car off and start it when it's warm. I don't recall it EVER doing it when you start the car up cold and drive it. I drive it to work and it never hesitates, by time I'm done work, the motor is cold so it doesn't do it.
I replaced the spark plugs, spark plug wires and coils two months ago due to a misfire.
EDIT: It might of even sounded like a backfire, I'm not sure.
