Tire size question
Tire size question
Could I fit 305/35r18 tires on 18x10 wheels??? The sticky says that 295's are the widest you can go on a 10" wheel, could I get away with the 305's?
I had 18X10.5 TT2's on the rear of my 99 WS6 (custom size) with 295 BFG's. They fit perfect, sidewall was parallel with the rim. Your talking about a rim that is 0.5in thinner in the rear with a tire that is 10mm wider. I wouldnt recommend it, that sticky is pretty much spot on with what you can and cant do. 295 is probably the widest you can go as listed.
