Vehicle Classifieds - Fs: 98 z28
View Full Version : Fs: 98 z28
cjvmboricua08
07-04-2012, 04:23 PM
well up for grabs is my 98 camaro.. unfinished turbo 5.3l build. just don't have the time or funds anymore to keep the project going plus i do have a Lean on it.
i'm located in the fort hood area. text me or email me for pics. here is the list of mods:
2007 lm7 5.3l iron block (9.5:1 compression)
317 heads
comp 918 springs
ls6 cam
mls head gaskets
ls7 lifters
ls2 timing chain
ls6 oil pump
underdrive pulley
comp hardened push rods
arp head and rod bolts
ls6 intake
dyno-tech 3.5 inch aluminum driveshaft
t56 rebuilt last year (2k miles)
stage 3 diamond clutch (2k miles)
10 bolt with 3.23 gears
bmr adjustable torque arm
yank torque arm relocation cross member
lakewood lower control arms and adjustable pan hard bar
sfc
dual intank walb 255 fuel pumps
speed in fuel rails
turbonetics fuel pressure regulator
modular turbo hotside
cxracing intercooler & piping kit
2 bar map sensor
60lbs injectors
6.0l exhaust manifods
turbowerks scavenge pump
hallman manual boost controller
RPS 50mm BOV
JGS 40mm wastegate
2x 12in pusher fans
battery relocated to trunk
mechanic boost gauge and aem wideband
3 in down pipe from turbo to CME tips through a magnaflow muffler
modular feed and drain lines with lsx oil feed block
needs:
-IT RUNS*** just need the following things and the finish the tune so it's done with.
-new turbo because of bad seal. i had gone with on3 76mm t4 .96 ar/.81ar but will do with anything from 70mm to 78mm turbo as long as it's a t4.
-it heats up, i'm thinking either thermostat or radiator. i will be installing a new thermostat next week.
-car does have it's normal wears.. passenger side window is slow (i have 2 window motors ready to be installed), seats have its wear.
-the ws6 wheels need some tlc.. a good polish job.
-i give the body a 7 out of 10.
i'd like $8,500 but willing to negotiate.
I'm sure i've forgotten a few things but i just need to get rid of this. it's been a hassle and at the moment i'm not in the place to be doing this. again.. if you're interested please text, call 8167193075 or email me at cjvmboricua08@sbcglobal.net for pictures.
thanks.
cjvmboricua08
07-07-2012, 05:08 PM
To the top! Open to offers but no low balling. I shop have a lean on it
cjvmboricua08
07-09-2012, 04:45 PM
8000obo
