Gears & Axles - 2 quick questions...
View Full Version : 2 quick questions...
Jadedbird
07-04-2012, 10:32 PM
1)whats the difference between 3 channel and 4 channel?
2)how do i uninstall a driveshaft so i can install my D/S loop?
thanks
XxApollynxX
07-04-2012, 11:02 PM
3 Channel rear end is a rear end with ABS only a 4 channel rear end is a rear end with TCS and ABS...
As for your driveshaft look on the end where the rear end is and there will be 2 "straps" with 2 bolts on each strap take the bolts off and remove the straps, remove the shaft from the yolk of the rear end and then slide it out of the trans. Bolt up your DSL then reinstall.
Jadedbird
07-04-2012, 11:04 PM
awesome thanks for the quick response.
will i need to realign anything or something of that sort?
SS SLP2
07-05-2012, 09:13 AM
"...will i need to realign anything or something of that sort?"
mark a strip across the rear end of the drive shaft- across the rear u joint- yoke
( kind of like a timeing mark) so that you may reinstall the drive shaft and yoke back in the same relationship. when removing the strips which connect the ujoint to the yoke wrap a wrap or two around the complete rear ujoint so you do not drop the two loose caps and loose the small bearings, also when re install be sure the caps
completely fit back in to the yoke
>Do not drop the loose caps and mis place the small bearing<
Johnny
Jadedbird
07-05-2012, 09:41 AM
Ok that's that is kinda what I figured. Just making sure.
Thanks all!
Scratch that...1 more question..
Can I put a 3 channel rear in my car? It has tcs but I always have it off.
So would I just tune the tcs off? Or what?
FirstYrLS1Z
07-05-2012, 10:38 AM
putting a 3 channel rear in your 4 channel car,you will lose BOTH ABS & TC.
Jadedbird
07-05-2012, 04:44 PM
I thought if I used my brake backing plates then I keep my abs.
FirstYrLS1Z
07-05-2012, 05:41 PM
partially correct.
using the backing plates with sensors AND axles from the 4 channel rear into the 3 channel rear will keep ABS & TC. you can't only keep ABS,TC comes along.
Jadedbird
07-05-2012, 05:50 PM
Well you learn somethig new everyday
