New LS1 Owners - Newbie Tech - springs
View Full Version : springs
william45
07-04-2012, 11:27 PM
installing new valve springs 02z28 635 lift cam stock heads duell springs what sould i torque them to
bww3588
07-05-2012, 03:05 AM
Torque what to?
Decadence75
07-05-2012, 05:37 AM
What exactly are you asking to torque down? Springs aren't torqued, they are compressed. If you are referring to the rocker arm bolts, those are 22 pound feet.
william45
07-05-2012, 10:29 AM
sorry what should i torque the rocker arms yelle terra 1.6
Decadence75
07-05-2012, 10:56 AM
22 pound feet
bww3588
07-05-2012, 11:03 AM
Depends, adjustable or non? Either way, go with what YT says.
BlackScreaminMachine
07-05-2012, 01:42 PM
Just throwing it out there, what is the cam and why are you tossing that much lift in a stock head. It does stall out and curious if its for "future cyl head install" Fly cutting??
william45
07-05-2012, 04:52 PM
there not adjutable, heads where polish&ported helion cam no fly cut very radical cam very hard on the top end put doable 635 lift
07-05-2012, 07:20 PM
Lobes must be know knife points
garygnu
07-05-2012, 08:39 PM
its best to install and torque rockers with the lifter on the base circle of the cam.put the came on #1 cylinder and tighten int valves #1,3,4,5. tighten exhaust valves #1,2,7,8.rotate the crank 360* and tighten int valves #2,6,7,8.tighten exh valves 3,4,5,6.
william45
07-05-2012, 09:43 PM
i think the lobes are fine i just keep wearing out my springs eveyother year tightening my springs in that sequence makes sense thank you i will be removing this cam next year looking for somthing more friendly
