GM Performance Cam for LS!?
Old 07-05-2012, 01:59 PM
hdvrod's Avatar
Default GM Performance Cam for LS!?
I have a '98 Z-28. I've recently ordered SLP long tube headers with high performance catalystic converters, a ported throttle body, LS6 intake and LS6 heads. I'd like to keep the car all GM and driveable. Does GM performance offer a cam that would deliver more horsepower and performace than the stock LS1 cam already in the car? Thanks for your input.
Old 07-05-2012, 02:13 PM
sweet99ss's Avatar
Ls6 cam or gm hot cam
Old 07-05-2012, 02:14 PM
Decadence75's Avatar
There is also the GMPP ASA cam if you want strictly GM parts
Old 07-05-2012, 02:55 PM
csess's Avatar
Check out the asa cam on scoggin dickey website. Think im gonna go the same route as you. Im gonna get there cnc'd ls2 heads an the asa cam. Should be a fun setup to drive.
Old 07-05-2012, 04:35 PM
sweet99ss's Avatar
What makes more power the hot cam or the asa cam?
Old 07-05-2012, 04:46 PM
The ASA is:
226/236 duration
.525 lift
110 LSA
Hot cam
218/228 duration
.525 lift
112 LSA
The ASA will obviously make more power over the hotcam. Though not much.
Old 07-05-2012, 05:28 PM
csess's Avatar
Yeah....pretty much comes down to mild or wild lope between the 112 lsa on the hott cam an the 110 lsa on the asa cam. Search asa cam on yahoo an listen to a couple of idle clips.
Old 07-05-2012, 05:29 PM
csess's Avatar
You also lose alittle on the low end with asa but i have a m6 with 4.11's so kinda makes up for it...imo.
Old 07-06-2012, 02:01 AM
Gunslinger09's Avatar
To give you an idea of the power difference GMPP puts both the ASA and Hot Cam in the Ls 376 crate motor. The ASA cam is in the 515 HP version and the Hot Cam is in the 480 HP version. As was mentioned the ASA is more agressive and makes power in a higher RPM range.
