Generation IV External Engine - How to Remove Intake Cover
View Full Version : How to Remove Intake Cover
69-er
07-05-2012, 08:19 PM
I did a web search and a search here but found nothing. I guess I'm the only one not smart enough to figure this out...
How is the intake manifold cover removed? All I see are two of the intake bolts at opposite corners that need to be removed. I tried inserting a screwdriver between the two and pried but no go.
What am I missing here?
Larry
SStressin
07-05-2012, 11:51 PM
off what car?
69-er
07-06-2012, 12:04 AM
LS2 in an '06 GTO
Blk98Vert
07-06-2012, 12:33 AM
Like on LS1GTO your intake does not come apart, im not sure where you got that from
LS1MCSS
07-06-2012, 05:08 AM
He's trying to get the plastic engine cover off. Not take the intake apart.
SStressin
07-06-2012, 08:44 AM
you mean the fuel rail covers?
69-er
07-06-2012, 09:35 AM
No, not the engine cover or the fuel rail covers. I thought I read that the upper portion of the intake manifold came off. What I've found so far is that it is a two piece manifold, but it is permanently, glued, bonded, etc to the bottom.
Not sure where I heard that. I'm an old school SBC AND BBC fan and the LS series is a motor I'm just starting to learn about.
Thanks guys!
Larry
Blk98Vert
07-06-2012, 11:39 AM
Read his post, yes he was
LS1MCSS
07-08-2012, 06:04 AM
Well, he can probably find a way to get it apart, but it won't be fit to use after that.
S10xGN
07-08-2012, 08:46 PM
Thanks guys!
Larry
Some (or all?) of the FAST manifolds can be taken apart but not the stockers...
