Fueling & Injection - Would I??????
01transampower
07-06-2012, 10:50 AM
Would I be able to run E-85 with 42lb an hour injectors on a heads cam only motor? All my mods are in my sig.
vaticano
07-06-2012, 11:27 AM
Yes. That's what i did at first.
01transampower
07-06-2012, 01:09 PM
What kind of increase in power did you see? From 91 or 93 octane? And did you run your stock fuel line with it?
vaticano
07-06-2012, 05:15 PM
Can't really say. I did not get it on a dyno, and I'm really not set up for drag racing so my times are always bad.
I later used the stock fuel lines with 2 pumps and 79# injectors at 58 psi. So the fuel line wont be an issue. They flow plenty for what you have.
01transampower
07-06-2012, 08:33 PM
Do you know how long the stock fule line would hold because I am being told I need to upgrade them so the e-85 doesnt chew through the stock stuff.
vaticano
07-06-2012, 10:21 PM
Don't believe the hype. I used them for 4 years or so for feed lines and now use the feed as a return for the last 2 years. I also run E-85 in my 05 GMC Sierra. It has 170,000 miles on it half using E-85.
The only issue I have seen is it leaves a sticky residue around the injector tip. Just run some 91 through it every so often and it cleans it off.
Ollie8974
07-07-2012, 06:15 AM
Do you know how long the stock fuel line would hold because I am being told I need to upgrade them so the e-85 doesn't chew through the stock stuff.
E 85 will not "Chew through" the stock nylon fuel line.
01transampower
07-07-2012, 09:48 AM
good to know guys thank you. Going to the tuner today and wanted to makesure i could go e-85 if i really wanted too.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
