Holley Dominator Wideband/Narrowband Question
Old 07-06-2012, 12:21 PM
corpserodeo666's Avatar
Default Holley Dominator Wideband/Narrowband Question
I have the Holley Dominator setup (not the HP). I would like to utilize a windeband sensor in each header since I am turbo. My question is. Do they make a harness for it that plugs in? Do I need to do that since I run an external AEM wideband sensor. Or Do I need to run just one?
Any help would be awesome.
Thanks.
Old 07-06-2012, 04:54 PM
NOS327's Avatar
The basic dominator main harness has a wideband connector in it and the 2nd channel wideband harness (possibly the 4x4 connector) is a direct plug and play for the second. Use their sensors, its a snap.
Old 07-06-2012, 05:39 PM
So is there a link to this or a part number? Can I run dual O2s with it?
Old 07-06-2012, 07:57 PM
soundengineer's Avatar
incorrect...the 4x4 is Just 4 ins and 4 outs... nothing more.. cannot be used for a 2nd wideband
the second wideband is part of the J2 Connector
you need this one
https://www.holley.com/558-401.asp
Old 07-07-2012, 02:39 AM
So my question is do I really need it? or do I just tap a hole for the one wide-band that I did get with the kit and use that for the Holley and the AEM for added security.
Old 07-07-2012, 08:27 AM
Naturally aspirated... probably not a problem to only have one wideband....
but its nice to have the 2nd one, and its not that expensive.
you will see a more consistent and smoother fueling when using 2 widebands.
Old 07-08-2012, 12:13 AM
NOS327's Avatar
you need this one
Yeah, was too lazy to look for sure on my phone.
Old 07-10-2012, 07:05 AM
bmf5150's Avatar
Thanks Soundengineer!,I'm ordering mine to
Quick Reply: Holley Dominator Wideband/Narrowband Question
