New LS1 Owners - Newbie Tech - I cannot get my exhaust off!!! What the hell
My6speedZ
07-06-2012, 04:30 PM
Ok my exhaust needs to be re worked but I can not get this thing to freaking move! I have blasted it down with PB tried rapping on it with a rubber mallet, and all kinds of elbow grease and Nothing! I think I would have to hook it to a car and yank it off the collector its so tight. It is like it practically welded itself. Help me out guys I don't want to have to cut it.
blue98Z
07-06-2012, 04:53 PM
Sawzall that shit :lol:
RPM WS6
07-06-2012, 05:02 PM
Slip fit? Slip fit rarely "slips" once it's been on for a while, especially if you ever drive it in bad weather.
98Ws698
07-06-2012, 05:06 PM
Tie one end of a rope to a tree and another to the exhaust and give it a good WOT!! lol
Maybe heated it up with a torch?
mjs1012
07-06-2012, 05:46 PM
drink a large redbull get under there and start shaking it back and forth as hard as you can from the back while screaming like a crazy asshole...that method has worked for me lol
My6speedZ
07-06-2012, 06:04 PM
damn... i guess that means I'll have to have to cut it off (it is slip fit) might be time to put some v-bands on it. That would help in the future if I need to drop it again.
My6speedZ
07-06-2012, 06:05 PM
LMAO that's exactly what I tired :bang:
ksnew
07-06-2012, 07:36 PM
1/4 stick of dynamite, light that shit, run...works every time.
My6speedZ
07-06-2012, 09:32 PM
That made me think of when me and Fbodyfunkie06 were at the track and that ricer made a pass came back and parked in front of us and had blow the packing out of his cheapo ebay muffler. HAH
ksnew
07-06-2012, 09:57 PM
lol you guys really hate on some ricers on here... dont get me wrong, i'm no oh i got a honda, lets go to autozone and trick it out kinda guy, but i'm sure alot of you guys would categorize me as a ricer... body kit, low offset wheels, "fart can", etc...
senicalj4579
07-06-2012, 10:38 PM
Oh man...exhaust is such a pita at times. I would just keep at it. Dont let it win!
My6speedZ
07-06-2012, 11:03 PM
Nah man, FD and FC are good looking cars. I don't hate tuner cars for the way they look. I like Supra and Rx7's but that's about it. WRX's and EVO's are kind of gay IMO, most of the reason I hate imports are because of the people that have them. My best friend has a really clean boosted civic and its a really fun ride.
Yeah, I'm going to spend sometime on it tomorrow I really don't want to cut it.
OSU Football Fan
07-07-2012, 12:06 AM
Stubborn exhaust slip fittings can be pretty frustrating. Especially when they're rusted together or crushed with U-bolt clamps.
Rubber mallets never worked for me. I always had to use a mini sledge hammer & 2x4 block so I didn't dent the piping.
If all else fails, hook a chain to the exhaust, get behind the car & start pulling. I've had to do it before when the slip fitting was rusted together.
Anyways good luck man. Hopefully you won't have to cut it.
blue98Z
07-07-2012, 05:53 AM
Since it's an X-pipe just use a 2x4 in the center of the X and smack it with a sledge hammer. It should move.
mjs1012
07-07-2012, 06:34 AM
Can you get the center section off or do you have it welded together as one piece? If you have a die grinder try cutting a little slit in the pipe where you're trying to get it off then get a hammer and chisel to open it up a little bit and losen it up that way.
mjs1012
07-07-2012, 06:38 AM
Or have someone heat it up om the collector then try my first method again lol.
TImmy_Jones
07-07-2012, 09:23 AM
Heat it, shake it, hit with hammer...it will move.
pnykillerz28ls1
07-11-2012, 05:46 PM
I had to cut a slit along the side of the pipe like half way down where it goes in and that let it open enough to get it off. And when i put the clamp back on it covered the cut and didnt leak at all.
motoo344
07-11-2012, 05:57 PM
I had the same issue before. As mentioned above, a sledge to the right spot will knock it right off. I didn't even have to hit it all that hard.
TransamGCS
07-11-2012, 06:50 PM
soak it down real good with pb blaster overnight, try heating with one of those little blue propane torches you get at home depot heat it up and start twisting and banging
FiredUpZ28
07-14-2012, 08:51 PM
I dont touch exhaust systems without a torch. I dont even bother to TRY and break em loose without heating them up. Especially if the car is over 5 years old. Is it crimped on (like with a band clamp)? You may need to cut it off and cut your losses.
My6speedZ
07-14-2012, 10:12 PM
Yeah she ended up getting sawzall.
