Drag Racing Tech - trying to get my cage certified
View Full Version : trying to get my cage certified
99french
07-06-2012, 07:54 PM
i just got the car back a couple weeks ago from midwest chassis. i had the crew there put in a chromoloy cage good for the 8.50 certification. i do have my window net, and a current set of belts too.
do i need to have the belts, window net, and the padding installed when i go to get the car certified?
i am going thurday night to get it done and hopefully i can get to racing just wanted to know what all had to be in the car when i get it inspected.
95killerz
07-06-2012, 08:27 PM
I think it has to bein race trim as it will be going down the track.
ssvert99
07-06-2012, 09:20 PM
all you need is the seat in place. no padding or belts should be necessary for the inspector to do his job... all he will look at is the general construction, type of welding process(TIG only for cm, MIG/TIG for mild), and the diameter/thickness of the cage material.
ctjohns
07-06-2012, 10:13 PM
x's 2. All you need is the cage and structure in place. All the extra's are the job of the track's tech staff. Chuck
99french
07-07-2012, 07:05 AM
Thanks guys I brain farted on what all I needed and what I didn't need
