BW S480 on a 5.3 opinions please
I am looking into building a notchback, but use a 5.3 turbo as my power source. I want to go to the track and first pass be a 9.9999999. Do you think this turbo would get me there on pump gas = S480 1.10 a/r 83mm Exh wheel
The 87 turbine wheel depending on backpressure can be worth up to around 75-100hp. On a 347ci LS1 based setup we worked on with a customer, his backpressure was pretty high, swapping to the 87mm turbine gained 72rwhp...nothing else changed.
