Pontiac GTO 2004-2006 - New GTO Clutch
skidmarkSS
07-07-2012, 12:40 PM
here is my new Monster Clutch Assembly, comes with everything you see here. I will post pictures of the thrashed stuff
http://i707.photobucket.com/albums/ww78/cjohnson2001/3.jpg
lo&sloSierra
07-07-2012, 12:43 PM
Do you already have a tick master?
lo&sloSierra
07-07-2012, 12:44 PM
I ask because the kit that comes with the tick master cylinder is a pretty good deal, and is way better than the stock one.
skidmarkSS
07-07-2012, 01:49 PM
I ask because the kit that comes with the tick master cylinder is a pretty good deal, and is way better than the stock one.done!
lo&sloSierra
07-07-2012, 01:53 PM
That's a good set up, same one I have.
Tishkevich
07-07-2012, 04:03 PM
That's attractive.
slayer performance
07-07-2012, 05:55 PM
pretty much what i have
skidmarkSS
07-10-2012, 10:53 AM
been driving it for about a week now,smooth as butter,a little bit of chatter but should wear off in a couple hundred miles or so.
svede1212
07-10-2012, 03:59 PM
Mine chatters a bit years later. You need to keep thrashing on it to get it to clear up. I have stayed away from the Tick as the stock one works great with new solid clutch lines. The stock clutch is self adjusting just like your brakes and the manual adjustment on the Tick can cause your slave to over extend and puke it's guts out.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
