Fueling & Injection - Fpr set up
USMC35thSS
07-07-2012, 01:57 PM
I'm going to add a FPR to my fuel rails and had a few questions.
1) Is this set up the correct way to do it on an 02 Camaro LS1?
2) Which FPR do you recommend?
3) Do I have to have a vacuum line connected to the FPR?
Any ideas or comments would be appreciated. Thanks
http://i1050.photobucket.com/albums/s406/jharris46/LS1FuelReturn.jpg
USMC35thSS
07-08-2012, 03:51 PM
Anyone running an aftermarket fuel pressure regulator that can help with this?????
Old Geezer
07-08-2012, 04:37 PM
That will work. If you vac reference the fpr, you will have to change the injector flow rate to a constant value. Leave the vac port open, no change needed.
USMC35thSS
07-08-2012, 05:01 PM
Ok thanks.
Anyone know of a good regulator that I should go with?
Ollie8974
07-09-2012, 08:35 AM
I have an Aeromotive that reads to 100 psi.
vacuum referenced.
Connected as your diagram.
USMC35thSS
07-10-2012, 06:00 PM
vacuum referenced.
I think that's the brand I'm gonna go with. So do I just leave the vacuum port open or do I close it off with a plug?
Ollie8974
07-11-2012, 07:00 AM
Mine is connected to a vacuum source.
Old Geezer
07-11-2012, 07:56 AM
you choose to not reference it, leave the port open to atmosphere...
A second thot... the old reg may still be in the picture. Only, it now has a longer return line on it?? I think I'd take it out, all together.
USMC35thSS
07-11-2012, 09:41 PM
OK
I'm going to take the old one out and just plug that block.
Looks good. But, if you're going to run a new return line why don't you run a new feed line and use the factory feed as the return instead? That way, you can use a larger line like an -8an for the feed.
USMC35thSS
07-12-2012, 03:57 PM
That's an awesome idea. I am definitely going to do that. Thanks
USMC35thSS
07-12-2012, 04:21 PM
Should I just gut the stock fuel filter on the supply line that I will be using as a return?
You could do that, or cap off the side of the T that goes to the filter and use the factory return. Just remember to remove the in tank regulator.
USMC35thSS
07-13-2012, 05:50 PM
Ok, will do. Thanks
