Cadillac CTS-V - before I order the wrong things...
RADEoN
07-07-2012, 08:20 PM
can someone confirm this is the proper part list?
Pilot Bearing (http://www.summitracing.com/parts/NAL-12557583/?rtype=10)
Flywheel Bolts 1 (http://www.summitracing.com/parts/ARP-100-2801/)
Flywheel Bolts 2 (http://www.summitracing.com/parts/ARP-200-2807/)
(1 or 2)
Balancer Bolt (http://www.summitracing.com/parts/NAL-12557840/)
Fuzzy_Wuzzy
07-07-2012, 08:58 PM
well i just ordered the LS7 clutch/ram flywheel set from Scoggin Dickey with ARP bolts. they sent me:
Chevy LS1 11mm Flywheel bolt set 330-2802
LS1 Hex Pressure Plate Bolt Kit 134-2201
scatillac
07-09-2012, 08:51 AM
(1 or 2)
The crank bolts on all LS motors are metric, unless it has a very early Scat aftermarket crank, which used the 7/16" bolts.
I'd spring for the ARP crank bolt (#234-2503) and the ARP flywheel bolts (#330-2802).
Your pilot bearing is correct, the same as the truck bearing.
BudRacing
07-09-2012, 11:14 AM
I think you need a tool to install the pilot bearing?
etcts-v
07-09-2012, 11:25 AM
I installed mine without a tool, was a little bit of a biotch but not too bad. If needed, you can rent them from orielly's.
The ARP bolts I used for the Flywheel were 330-2802
I also went with the ARP harmonic balancer bolt due to the fact that I read so many stories of people's bolts backing out as well as not needing to stretch the ARP bolts.
http://www.ebay.com/itm/New-ARP-Crank-Harmonic-Balancer-Bolt-234-2503-LS1-LS2-LS3-LS6-/280907020842?pt=Motors_Car_Truck_Parts_Accessories&hash=item41675cfa2a&vxp=mtr#ht_500wt_1180
punishmentcycle
07-10-2012, 10:49 AM
they rent the pilot bearing tool at any auto zone.. its just a slide hammer with a tip that spreads when u tighten the jam nut.. then just lightly tap it in with a deadblow. i always freeze a bearing before install as it contracts it a bit and makes em easy to slide in..once warmed up its tight as a virgin
punishmentcycle
07-10-2012, 10:51 AM
also OP..remember that the dual mass uses longer bolts for the flywheel..when u change it to a single mass youll need the ls1 flywheel bolts
JJSimon904
07-10-2012, 10:54 AM
The stock bolt won't back out if it is installed properly.
etcts-v
07-10-2012, 10:56 AM
Obviously.. The point is with the stretch on the stock bolt you run more of a risk of not installing properly.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
