Fueling & Injection - -06 feed for 700rwhp turbo
View Full Version : -06 feed for 700rwhp turbo
nasty_ss
07-08-2012, 01:30 AM
so i was wondering if i should just go bigger diameter on my fuel feed line. I plan on running twin 255 pumps into a single -6 line and putting a Y at the rails where a -6 line runs into the rear of each rail. i was going to put a bypass regulator at the front of both rails with the return going back into the stock feed line.
i wasn't sure if -6 feed would be adequate but seeing as how most fuel rails would bottleneck a -8 or above feed down to 3/8th or -6 inner diameter at the rail anyway, i figured -6 would be ok as long as pressure holds in the rail.
the goal is to make 700 rwhp on 93octane with this setup.
Lonnies Performance
07-08-2012, 09:38 AM
If you are keeping the stock lines as a cost savings, that is 1 thing....
Buying a new -6 line instead of -8 is a waste of money. It is not much different flow wise than the stock lines, & not much cheaper than -8.
If you are spending your hard earned money, do it right the first time & run a -8 line.
