chevrunner21
07-08-2012, 11:15 AM
I've been reading thread after thread and have a rough idea of what I need but I wana double check with you guys before i do anything here.
So I've gotta buy:
-a hiltsy t/a mount
-an aftermarket t/a
What exactly is the best t/a to run with this mount??
-8.8 explorer housing
Which 8.8 housing would i need to look for that i could just grind the 10bolt tubes down to slide into the 8.8 without having to have custom sleeves fabbed?? is this also the same rear that would have the 31spline 4.10 posi??
-Moser custom axles
-Everyone says to also upgrade to the carbon clutch packs so i guess ill buy that also.
will my stock drive shaft work?? also what u joint do i need to order??
and all my stock stuff should bolt right back up right?? Am I missing anything here? anything else you'd recommend??
So I've gotta buy:
-a hiltsy t/a mount
-an aftermarket t/a
-Moser custom axles
