New LS1 Owners - Newbie Tech - LS! line bore out 2 thousands
Larryseng
07-08-2012, 04:14 PM
I have a 5.7 aluminum block I plan to build for a air boat.
I took it to the machine shop and checking the line bore he found it out 2 thousands left to right.
What do I need to do about this?
Thanks for any help
Larry
sepsis
07-08-2012, 05:31 PM
Didn't the machine shop offer any advice?
Larryseng
07-08-2012, 07:17 PM
No he has not worked with the ls1 block.
The bearing caps are different so he was unsure how to correct the left to right as the caps go down into the block.
Larry
bww3588
07-08-2012, 08:57 PM
First off, take it somewhere that has delt with ls engines before.
2nd. Make sure the shop has the main caps pointing the right direction.
redtan
07-12-2012, 10:04 AM
That's like going to a veterinarian and asking about a tooth ache...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
