Piston Decision Help
Hey Everyone,
I have a 99 Pontiac Trans Am that i have recently taken apart. I've already made the decision to go with the 383 lunati rotating assembly, 3.903" Bore, 4.000" stroke, 6.125 rod length. I need advice or opinions on which cc piston i need or compression ratio to us that would work great on the stock heads. Thanks
LS1Tech Premium Sponsor
Which stock heads are you going to be running? What are the pistons options they have for the kit you are considering?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
