General Maintenance & Repairs - power steering fluid leak :(
View Full Version : power steering fluid leak :(
its turbo time
07-08-2012, 05:59 PM
This is on a 2002 ss, I noticed my car has been leaking power steering fluid and I was able to pinpoint the location of the leak. It is basically leaking right out of the back side of the pump right onto the alternator. I plan on taking it off to take a look at it on Tuesday. What do you guys think I will I need to replace? Or should I just go ahead and get a whole new pump?
wssix99
07-08-2012, 08:26 PM
Its common for the fluid to go bad and boil over out of the tank. Do you think that could be happening to you? The only seal in that area is between the tank and the pump. Its a low pressure seal and doesn't typically leak.
If you are getting boil-overs, a fluid flush may fix your problem and enhanced cooling will help you get more mileage out of the next fluid change.
tom falco
07-08-2012, 08:43 PM
Check the HIGH pressure hose They split. You can get a kit from the dealer that has all the seals and parts necessary to repair the stock pump. I rebuild them all the time. But the hoses have a nasty habit of splitting and they only leak under pressure.
BadxLS1
07-09-2012, 12:52 AM
This happened to me and I didn't realize it until my alternator started making a funny noise, took it off and out poured all the power steering fluid.
01wss6
07-09-2012, 12:59 AM
My high pressure hose leaked only when the wheel turned and the car was on. If it sat it would leak very little. The advanced auto by me had one in stock for about $40 and was very simple install just a little messy.
its turbo time
07-09-2012, 07:58 AM
Honestly I bet I've replaced all the fluid since this has been going on because it leaks out of the reservoir until it is empty if I don't keep filling it. It doesn't seem to be leaking out of the high pressure hose though, it is coming right out of the back of the pump. I can see it dripping onto my alternator. It will not leak if I just fill it up but it leaks after I turn it on and run it for a little while. I guess my best bet is just to take it off and send it somewhere to be rebuilt. Any suggestions?
wssix99
07-09-2012, 08:39 AM
Yea, sounds like a rebuild is in order.. I recommend TurnOne. If you don't want a performance mod on the pump, they will do a stock rebuild if you ask for it.
tom falco
07-10-2012, 02:57 PM
Actually rebuilding them is a snap. I can rebuild one wearing boxing gloves in a 1/2 hour. Mostly the high pressure line leaks under pressure. But i have rebuilt many pumps in my shop for leaks!!
MrEddie
07-11-2012, 12:04 AM
Yup, I would go with a turnone pump as well. I autocross and had my old pump spew fluid (as it should) when hot out the vent cap. The turnone pump runs at a lower pressure so it's a little harder to turn when not moving, but not noticeable at speed (no factory power steering cooler either). The pump runs very well even in July in Texas! No fluid spills to clean up.:nod:
tom falco
07-11-2012, 03:01 PM
You can buy relief valves for the stock pump if you believe it is a pressure thing???!!!. They make relief valves in all different configurations. If not shell out bucks for a pump that has a modified valve and spring. I would rather use the money for other things!!!
