Western Members - swap question
Chuchin2o9
07-08-2012, 07:40 PM
A friend of mine is looking into swapping a 6.0L from a 2006 Escalade ext. And he's going to put a callaway procharger on it. He also wants to put a cam in it. Now the question is. Will the stock springs and lifters work well with a 242/244 cam.
djsanchez2
07-08-2012, 07:51 PM
Springs? FUCK NO! Time to look for a dual spring option, especially for a boost application.
Lifters, maybe, but i would seriously consider upgrading while you have them out.
LS1Adam84
07-08-2012, 07:57 PM
What he said, I think the lifters should be fine, how many miles are on them? I would say to just pick up a set of LS7 lifters for now since they are pretty affordable and you can use stock pushrods with them, well ideally, it is still good to check pushrod length regardless just to be safe and have everything correct.
ss.slp.ls1
07-09-2012, 04:07 PM
I think he meant stock length, not the stock pushrods. You'll want some chromemoly pushrods.
LS1Adam84
07-09-2012, 04:13 PM
Thanks SRJ you are correct, stock length. I appreciate that.:chug:
Chuchin2o9
07-09-2012, 10:39 PM
Ok. Thanks both of you I kinda figured he'd have to go with double springs. It just seems like he'd be having too much hp for them to withstand. I honestly don't know why he didn't get the whole cam package with lifters and springs I'm sure they had one. But I figure he can get a good set of lifters springs and pushrods for say maybe 400 depending
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
