New LS1 Owners - Newbie Tech - Tune without A/C pulley affect car after A/C pulley is installed?
Drew-Bot
07-09-2012, 09:30 AM
I don't know how silly this sounds, but I'm not sure if I had an A/C pulley when my car was tuned. It was during a time I had not driven my car much and a/c or heat was not needed. So my serpentine belt cam off and while installing it I noticed my A/C pulley was broken and there was no belt. So i replaced my pulley and both belts. Starts up and runs fine, but when i turn A/C on my car wants to cut out, and sometimes it does. While sitting it can keep running but it goes from 1k rpms to about 6-700 rpms and then comes up and drops down and does this for a good 30 seconds then levels out at around 900-1000 but lets say I'm coming to a stop and my A/C is on 7/10 times it dies out, or I recover at the last second. So my question is does it sound like I need my car retuned?
TransamGCS
07-09-2012, 06:13 PM
yes it needs to be retuned for when you turn on the AC
Drew-Bot
07-09-2012, 07:24 PM
lol are you serious that can actually affect the tune that much? I mean i can't believe just having the A/C on can kill my engine.
bamaballa205
07-10-2012, 03:21 AM
It affects it. I'm dealing with the same issue right now. Had the car tuned a few months ago without the AC installed. Then this heat started kicking my ass when I did drive it. Installed the compressor and now the bitch don't like to idle pulling up to stop lights with the ac running. Luckily my tuner is going to fix it for me anyway.
hiram007
07-10-2012, 11:27 AM
Yes, adding AC to a car that was tuned to run without it will affect it. Any changes you make after a tune will require a retune to compensate. The effect of some changes will be more than others but a tune should take of it
Drew-Bot
07-10-2012, 06:45 PM
Yes, adding AC to a car that was tuned to run without it will affect it. Any changes you make after a tune will require a retune to compensate. The effect of some changes will be more than others but a tune should take of it Its not that it was tuned to run without it, its my daily driver the a/c was just never on while we tuned it i suppose. I moved to orlando from maryland where my tuner. Can i have someone just tweak my tune without paying for a full blown tune? I suppose it is up to a shop or tuner. Anyone in the orlando or florida area kno a good place?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
