Carbureted LSX forum - Anyone have a msd box go bad?
sandeggo
07-09-2012, 10:37 AM
6012 box
For the last week I've been chasing a misfire on my boat. I know what cylinder it was because I could feel the header tube after running it. Then on Saturday I was running and all of a sudden it shut off and wouldn't refire. I ruled out all the easy stuff like fuel, grounds, connections, etc. the only thing I can think is the box went out. Does msd rebuild these?
Stroked96Bowtie
07-09-2012, 11:58 AM
Ive heard of it, never experienced it. I know you can send most if not ALL MSD stuff back to have it 'refreshed/rebuilt'.
tennerv8
07-09-2012, 12:02 PM
If msd can't get there quality control figured out then that mallory LS box looks better every day...
camarof41_383
07-09-2012, 12:07 PM
I had to send my 6010 back for repair/replacement. Luckily it was still underwarry, they sent me a new one within a few weeks at no charge.
streetknight2
07-09-2012, 01:42 PM
Few weeks? That's what worries me. My buddies burned up, I had one on the shelf for my build, so I put it on his car to not miss any races. Sent his back and no word yet. Now I'm a couple weeks away from needing one. Hope they get it soon.
sandeggo
07-09-2012, 02:17 PM
That Mallory unit is pricy
What's the warranty on a 6012 box?
The thing that's really upsetting is this box lasted a little over a year, but it's on a boat that only sees use six months out of the year, 2 days, every other weekend. So it has a total run time of maybe 40-50 hours tops.:bang:
camarof41_383
07-09-2012, 02:28 PM
The turn around time is why I bought a spare box to use if another one fails. I got a pretty good deal on one that I bought from another ls1tech member. It sucks having to spend money on a spare but a bad box won't keep the car off the track/road now....its just other stuff lol.
sandeggo
07-09-2012, 02:29 PM
Just talked to msd, he thinks it may be a crank sensor. Also 6012 boxes aren't repairable.
The boat is in AZ, I'm in CA. It will be a few weeks until I can test it. It will be an awesome weekend if I go out there and the crank sensor is good and the box is bad with no replacement.
bad67ls
07-09-2012, 02:50 PM
hook a laptop up to it and see if it communicates. when the one in my car shit the bed it started hitting the wrong cylinders while cranking, started smoking and then nothing. hooked a laptop up to it and no communication.
brought it into sk and they got me back on the road right quick.
ZONES89RS
07-09-2012, 05:08 PM
Dont know the warranty time on these. I have never had one go bad and i use more than anyone of this site probably, had a friend fry one due to bad ground. MSD warrantied the 6010, they did not rebuild/repair, they sent a new one. So now i have a spare 6010 harness, LOL.
The quality of them is damn good as far as i am concerned, other things an go bad. A coil, crank sensor, ect. The 6010 is not repairable i assume if they replaced the one my buddy used. I have personally built 7 or 8 cars with them and none went bad, jus the one a friend used because he tried to ground it poorly. A boat is different, but if it was direct to the battery with a simple solenoid and cut off, then that is probably unusual. No water hot in it i assume? I had a missfire from spraying mine. It cleared up though.
1994z
07-09-2012, 06:03 PM
we thought we had a problem with our msd box. chased the problem for a week. we found it.. talked to msd tech line 4 or 5 times last friday and edgar really knows his chit. now its off to callies.
S10xGN
07-09-2012, 06:47 PM
Ouch! Was that making any noise?
ZONES89RS
07-09-2012, 08:10 PM
That would peace me off.....
1994z
07-09-2012, 09:28 PM
couldnt tell on the noise its in a race car with open headers. you could barely see where it was rubbing the main cap, kinda left a shinny mark on it. talked to callies friday they said they had gotten a bad batch of wheels from gm that went on these cranks from november of last year till march of this year. so were having a billet one put on. we got about 12 passes on it before we went to commerce for the chp race, first pass at about 1000 ft. mark it sounded like it hit the rev. limiter he backed off and let it coast till the turn off. made it to the trailer and shut it off hasnt ran since. till i talked to edgar at msd tech we went thru some stuff, then he had me set the inital timing to 45 degrees straight across the board and it fired up and ran. i tried setting it at 35 and 55 degrees all it would do is backfire thru the carb. thats when he came to the conclusion it spun the reluctor wheel. pulled the crank and there it was.:bomb:
Pop N Wood
07-10-2012, 05:40 AM
I was thinking the same thing. When you hook up a lap top it gives you total run time on the box.
sandeggo
07-10-2012, 09:00 AM
Thanks for all the replies, I'll have to wait a few weeks until I can get back out to the river to test. I'll come back with my findings
Thumpn
07-15-2012, 01:06 PM
I looked at the mallory box, the problem with it is you have to add the distributor system to your Ls for it to work, it is not a plug and go like the MSD.
now as for the problems with the msd box, Yes i have had mine go bad! it stopped telling the coils to spark. I sent mine in and got another box pluged it in and as soon as i did i heard a pop from inside the box. I dont know what it was but I am very lost now trying to figure out what is causing the problem with the box. I have been on with MSD trying to figure out testing of any thing that plugs into the harness and I still cant find a problem. the only thing we can figure out is the I have a shorted out coil and it is back feeding into the box. but the only way I can test the coils is to power them up with the box. If I do that again it may pop the box again so now I have to replace all the coils to eliminate that possibility. sorry about the rant got carried away with my problem.
Doug G
07-15-2012, 02:17 PM
MSD 6010 Limited Warranty
1 year from time of purchase, under normal use when properly installed and purchased from an authorized dealer.
Warranty is VOID if purchased through an auction website.
bluethunder364
07-15-2012, 02:38 PM
I have been chasing a skipping condition @ 5,000RPM with my car. Talked with MSD last week and they suggested another ground. Have not done a road test yet to see if it helps. Checked every other thing I could think of as the culprit. My 6010 has only 46 hrs on it, can't imagine it could be bad, motor runs like a champ up to that rpm point. Really frustrated with it!
UPDATE: the extra ground did nothing, still no good. Pulled it today and off to MSD to check it out
Pop N Wood
07-15-2012, 03:19 PM
Should be a simple matter to test the coils individually using nothing more than 12V power and a 9V battery as a trigger signal.
Try a youtube search, I'll be a dollar someone has posted a video.
Should be hellaciously cheaper than replacing the full set of coils.
ZONES89RS
07-15-2012, 05:49 PM
Where is it grounded? If it is to a painted surface, that can do it.
Thumpn
07-16-2012, 12:18 AM
I have done a tube search and all the off motor tests have been done with a frequency generator and Osc scope, nothing as simple ass giving power.
It is grounded directly to the battery.
ZONES89RS
07-16-2012, 06:44 PM
Why size wire?
Pop N Wood
07-16-2012, 08:44 PM
http://i137.photobucket.com/albums/q213/WhatsADSM/CoilSwap/ls2_coil_schematic.gif
For an LS2 coil hook terminals A&B to a ground and +12V from the battery to terminals D. Then touch a 9V battery across C+ and ground. That ought to fire the coil.
Probably not a 100% test, the coils could go weak when hit at a high rate, but this will definitely find a dead bad one.
Thumpn
07-17-2012, 12:47 AM
Why size wire?
the wire size from my MSD box to battery is a 10awg wire and the run is about 6 ft.
i finally figured a way to test my coils. here is a video.
http://www.youtube.com/watch?v=UdjtZ9X2FA8
ZONES89RS
07-17-2012, 06:40 AM
I ground mine to the block.
Thumpn
07-17-2012, 08:28 AM
my msd block is inside on my dash.
http://i153.photobucket.com/albums/s233/fizzer46/Mobile%20Uploads/IMG_4131.jpg
get a big block Kevin......then you can get out of your own way on the river. lol
BLK95-Z
07-18-2012, 10:22 PM
If its carbed why not just run a distributor?
Im considering carbing my race car
sandeggo
07-18-2012, 11:12 PM
Haha the goal will be to run with you if not pass ya
Wont happen, its getting a freshen up.....you can run with the new boat all day...if it will run haha
sandeggo
07-31-2012, 08:58 PM
Just because I hate to let threads die without solution. The problem with all the misfires ended up being a faulty crank position sensor.
pairof69s
08-01-2012, 12:39 AM
nice to hear ya got it straight....:guns:
sandeggo
11-30-2012, 10:42 AM
guess I should update that it in fact was not the sensor but a broken piston.
NemeSS
11-30-2012, 02:00 PM
yea, that usually is not so great for power making.
sandeggo
11-30-2012, 02:13 PM
Haha but it still started and ran fine for months. It was just a V7
ZONES89RS
11-30-2012, 07:40 PM
Well, how did it do? Lol
sandeggo
11-30-2012, 07:49 PM
Surprisingly well. It was down on rpm and you could tell something wasn't right but I drove the snot out of it from may through October like that. Still did over 60 mph
