T Rex vs racenet's 238/240
Old 04-02-2004, 12:32 AM
chrdij's Avatar
Default T Rex vs racenet's 238/240
I was checking a few sites on the net and came across Racenet. They have a cam that is 238/240 .605-.609 ona 112 Lsa by Compcams also. I know the T rex has a 110 lsa and little more lift and Dur 242/248 .608/612, my question is... would you notice any diffrence in performance and at idle? I have an A4 so I thought Racenets cam maybe be a little more drivable and not slurg as much. BTW Racenet sells this came for $339.95!
Old 04-02-2004, 03:19 AM
distortion_69's Avatar
I'm not sure there'd be much more than 10-15rwhp at most, but the thing is.. Racenet.net doesn't have the best reputation on the net. I ordered 3k worth of parts from them, and alot of them were drop shipped. Some took up to a month after ordering them. I did receive all my parts. However, several others have posted that they did not on camaroz28.com, and possibly here as well. I'd try to stick with a sponser if at all possible. Especially when racenet has such a bad reputation.
Josh
Old 04-02-2004, 12:56 PM
chrdij's Avatar
Josh
Yeah I know what you mean by the month order. I have ordered many things from racenet and they do take about a month or so to get. You have me thinking twice on the cam, thanks for your help!
chris
Old 04-02-2004, 01:05 PM
Restricted User
CAT3's Avatar
Chris, you would really have to have all the specs for the cam, lobe type, all that. As I have been reading, theres a lot more to how a cam acts/pulls and the power it makes than the lift, duration, lsa. Ramp rate, advance, ICl, type of lobe, and so much crap. The only way to tell you the answer between them without all that info, is to install and run each one on the same car and compare. Sorry for not adding to your answers.
Good luck,
Charlie.
Old 04-02-2004, 01:19 PM
chrdij's Avatar
Good luck,
Charlie.
Your right on the info, all that racenet gave was the basics, but I would love to try it out with these ported ls1 heads! Not sure if you could possibly tell the diffrence in the sound at idle by the info given?
Old 04-02-2004, 01:52 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
The old Internet Racer Supply aka IRS became Racenet a few years back. IRS had a rep a being a bunch of butt pirates.
Old 04-02-2004, 02:31 PM
gator's 99TA's Avatar
i have heard nothing but bad things from racenet. a lot of mustang guys got ripped from them or took months to get their products. not cool.
Old 04-02-2004, 09:47 PM
CamaroCain's Avatar
just stick with one of our sponsors----------->
I do have a cam close to that size in my car right now, its a 238/242 .605/.610 112+4, but it is also paired with some ported heads, I got it from Texas Speed & Performance, they also have a few other big cams in the works.
Old 04-04-2004, 01:17 PM
jtz28's Avatar
I ran the old tr224 cam for over a year and pulled it out put in the AMS 239 cam. Picked up 40+rwhp OVER my old cam. Its a bad *** cam and idles perfect in my A4.
Old 04-04-2004, 04:04 PM
STF veteran / 10 second club
x phantom x's Avatar
Old 04-04-2004, 05:14 PM
c5blkvette's Avatar
I ordered $900 worth of stuff from them. Even though the wait was longer (3 weeks), I did get the best prices on the internet...probably saved around $300 compared to everyone else. Personally speaking, their customer service seemed to be OK.
Old 04-04-2004, 07:53 PM
AMS - Arlington Motor Sports?
Old 04-04-2004, 07:55 PM
z28hokie's Avatar
Arlington VA?
Old 04-06-2004, 11:53 AM
BBADWS6's Avatar
The cam you are looking at is an off the shelf comp grind. You can get it from anyone that sells comp products. I would not order it from race net, the need to get their act together. It took me over a month to get some gears that were suppose to take 4 days.
Old 04-06-2004, 12:00 PM
Brains's Avatar
FWIW -- last I knew that cam is sitting on the shelf over there. Its actually the same exact cam I have in my car, I got it from Dennis @ Racenet (he's local to me). Its a standard XE-R grind, the lobes are in Comp's catalog 2 degrees advance ground in BTW.
Old 04-06-2004, 12:20 PM
D2REngineering's Avatar
Will the AMS 239 still keep me emissions legal in California?
Old 04-06-2004, 12:31 PM
jmX
jmX's Avatar
I'd have to guess no.
Old 04-06-2004, 01:46 PM
Brains's Avatar
I was under the impression that putting ANYTHING in your car (including out-of-state passengers, I'm sure) is illegal out there.
Old 04-06-2004, 02:35 PM
Proud2bSS's Avatar
^Hollywood ricer stickers excluded, of course....
Old 04-06-2004, 10:25 PM
Any ideas for a cam that would keep me up to snuff (sorry about the pun) with emissions and still give me some hp/tq?
