Fueling & Injection - Any direct replacement fuel cells for 98 fbody
Cool28
07-09-2012, 12:19 PM
I see nasty has one but only 14 gallon. I want a direct replacement fuel cell that holds stock gallons and will support 1200+rwhp. Stainless braided line fuel line a plus
minytrker
07-11-2012, 11:09 AM
The one from nasty performance is your best bet, is 2 gallons that big a deal. I have it in my racecar, its a really nice piece.
Nasty N8
07-11-2012, 12:17 PM
The sumped tank is very close to stock. The ProTouring tank is the exact same just the pump assembly takes up some volume. We can set you up with complete fuel system give me a call I will get you what you need.
badger89
07-11-2012, 02:44 PM
can anyone tell me if the racetronix fuel pump replacement kit for the 98 fbody by passes all the old wiring? a wire broke off at the base of the pigtail next to the pressure sensor. any help would be great!!!
Nasty N8
07-13-2012, 11:22 AM
No sorry it is inline with the factory wiring as the trigger. Connector pins can be replaced any parts store should have them.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
