Stupid vacuum question
This sounds stupid, but I can't find a clear answer.
On the LS6 intake, which ports see both vacuum and boost?
I have the brake booster line T'd off to a vacuum block for FPR/boost gauge reference (the check valve is still on the far side of the line so the booster will only see vacuum), but for the ease of use I'd like to run the BOV vacuum line directly to the intake.
Does the brass fitting in this picture see both?
Thanks!
Thanks!
The fitting that I believe used to be for the PCV system on the other side of that brass fitting is what I use as a reference. I ran a line from that to a vacuum block and referenced my secondary pump hobbs, meth controller, and BOV from there.
But yeah, that brass fitting sees both as well.
