ikaros23
07-09-2012, 03:20 PM
just created this new threat cause the other one wasnt getting any attention lol. this is how it looks after some sanding with 80 grit. Im a complety noob in this but I would like to learn. is the grey color thing primer. are the black spots that I sanded bare plastic. on the black spots the webs are till a little visible will they go away after I spray primer. how deep should I go with the sanding. the paint is falling apart at the center probably because of a hit. should I sand the entire bumper or just the damage spots . thanks for reading:D
sjsingle1
07-09-2012, 03:33 PM
a flexible high fill primer will do the trick
ikaros23
07-09-2012, 03:45 PM
any brands and where to look
xBrandonx
07-09-2012, 04:49 PM
I'm trying to get the spider cracks out of mine too and so is this other guy, check out these links
http://ls1tech.com/forums/paint-body-work/1553687-far-enough.html
http://ls1tech.com/forums/paint-body-work/1540280-spider-webbing.html
Do, 80, 180, 320. I was surprised, after I sanded with 320, it was like the spider webs just vanished. I'm getting mine painted the 21st. I need to sand around the bird logo a little more, I can still see some cracking.
http://i.imgur.com/Wb7Phh.jpg
http://i.imgur.com/9RMf3.jpg
Jr.Samples
07-10-2012, 11:40 AM
Remove the bird logo. It looks cleaner.
