Corvette Performance - How to get C6 Z06 performance from a C5 Z06?
VandykeT/A
07-09-2012, 08:31 PM
What would it take for a C5 Z06 to run as well as a C6 Z06?
Mike@Diablosport
07-09-2012, 08:43 PM
Power and suspension-wise?
A good H/C/I combo will easily make the same or better peak HP as a stock LS7, but to match the torque curve will require cubic inches or forced induction.
IMO a good set of coil overs and a proper set of wheels and tires will make the C5 out handle the C6Z for the most part.
30th t/a
07-09-2012, 08:59 PM
Buy a LS7 and have it installed into the C5 Z06. Problem solved :nod:
TransAmcoupe98
07-09-2012, 09:35 PM
Nitrous...or some sort of forced induction. Vortech blowers have become popular as hell on c5's. One of those on 8 psi, c6Z shouldnt be too much of a problem.
breze84
07-10-2012, 12:10 AM
A good cam, full exhaust and a good tune... With your heads ported and a FAST intake you should kill one no problem... A good H/C/I setup with tune should be upper 400RWHP....
TransAmcoupe98
07-10-2012, 01:53 AM
Oh it will take more than that my friend. Ask me how I know...twice. Ported LS6 heads, cam, exhaust and FAST will put up a damn good fight but it will be a drivers race with a slight edge to the C6Z. That thing is stupid.
breze84
07-13-2012, 12:42 AM
Well something is very wrong with your car then... Dont get me wrong the C6Z is a good car but they weigh more then the C5Z and make around 440 RWHP with similar gearing... A good H/C/I and im not talking a slap job setup will put you in the 480 RWHP range and I have seen a few a cunt hair over 500 RWHP, That with a car that already weighs 3050lbs is pretty fucking deadly... Solid 10 second car all day....
MS4 Cam, Full exhaust, Stock heads & Intake, AMS Tune and I can pull away from C6Z's... Ask me HOW I KNOW lol....
http://www.youtube.com/watch?v=sg0S6Lv_axo&list=UUxbLkmUyfzXBefPJP8-cbSA&index=1&feature=plcp
baalic
07-13-2012, 12:48 AM
I approve this message.
9Green-Z8
07-13-2012, 01:15 AM
do you have a c5 zo6 OP or just curious
TransAmcoupe98
07-13-2012, 04:00 AM
Go find a C6Z and race it and put ups video please. You are suggesting a cam only z06 (stock ls6 heads) will pull a c6z??
lemons12
07-13-2012, 04:23 AM
C6z.. Mid 120 traps all day.. Will require heads and cam with bolt ons minimum to match that.
ysb02
07-13-2012, 08:14 AM
c6zs will put out ~500 rwhp with headers / cai / tune. It will take a very very strong H/C/I c5z to do so.
Crate motor LS7 is 13.5k, you can probably have a nice ~575rwhp 440ci built for ~$10k.
VandykeT/A
07-13-2012, 10:15 AM
I'm just curious about it. I've been considering buying either a C5Z or a C6 base but I want something I've got more potential with than my Fbody. I knew the C5 was lighter but still had the same 5.7 bottom end. I was just curious as to whether the weight difference Fbody to Vette was enough to let a 5.7 car run as good as the LS7. I've been leaning more toward a LS3 C6 lately mainly because I see cam only cars are making almost 500rwhp.
venom ws7
07-13-2012, 02:32 PM
Here is my friend's 00 C5 I built with the help of TSP
Pulls boltons C6 ZO6 :D
Built LS2 6.0 H/C/I 483rwhp
http://www.youtube.com/watch?v=2pYszdvKD6o
TransAmcoupe98
07-13-2012, 09:56 PM
Venom, whats going on with your setup? You switching it up?
ProMaroZ
07-14-2012, 03:10 AM
It's a bit disorienting trying to drive anywhere around any speed limit after a run like that, isnt it?
venom ws7
07-14-2012, 04:43 PM
I'm selling the complete ST80 Kit (which I'm sure I could've made 850-900rwhp with since I made 670rwhp 11psi with fat A/F ratio, Hot weather and 91octane)
I'm going with something bigger or buying C6 ZO6 Not sure yet !!! :)
:D Hell yes !!!
GARY2004Z06
07-15-2012, 08:04 AM
If we are talking strickly drag racing and a completely bonestock C6Z with DRs only, a full bolt-on C5Z would be able to keep up with that C6Z. With that stated, a good H/C package would be a much better choice for the mission.
Pulls most boltons C6 ZO6 :D
Fixed. ;)
Very strong running LS2. :thumb:
TransAmcoupe98
07-15-2012, 08:07 AM
A c6z on radials is running very low 11's @ 124-125. A full bolt on (not H/C) C5Z would have a VERY hard time keeping up with that.
GARY2004Z06
07-15-2012, 12:13 PM
I do agree with you that it would be very difficult; however, it's still possible. :D
C5natie
07-19-2012, 04:05 AM
LS3 with a cam and bolt ons.
Vette Moto
07-19-2012, 07:34 PM
My C5Z with every imaginable boltons could not pace with a C6Z with headers/cai/exhaust/tune. 473 whp vs 509 whp = 424 wtq/480wtq
Vette Moto
07-19-2012, 07:37 PM
It may be a different story if I had 3.90 or 4.10 gear though
ysb02
07-20-2012, 12:38 PM
No shock. c6z uses the lower MN6 gearing from the base C5 coupe but adds the 7k redline. Only better gearing is probably the ZR1 ratio.
youngrigo
07-31-2012, 09:32 PM
Procharger and see them in your rear view all day long... Ask me how i know
c5z16z
07-31-2012, 11:57 PM
YEAAHHHH BUDDY :bigun2: ,,, would a c5z ls6 cammed, A&A at 8 psi with ported LS6 243 heads, full exhaust make 675 RWHP?
back to the topic ,,,,,,, i agree i think a 8 psi kit on a stock ls6 would be enough to take the win..
vetteboy2k
08-02-2012, 05:15 PM
A well setup/driven H/C c5z is a mid 10 second car and better in good air.
A well driven c6Z is a high 10 second car in good air.
With the right setup and drive I have no doubt that a cam only c5Z can run 10.75 which would be on par with the fastest c6Z's on drag radials.
vetteboy2k
08-02-2012, 05:17 PM
Fixed. ;)
You get very accurate feedback if you take advice from someone who has done it before on the highest level with both vehicles in question like this fella above.
SStheBest
08-14-2012, 11:24 PM
I think you should change that to EXCEPTIONALLY well driven. Bc 10sec Stock C6Z ARE NOT common. I agree with the consesus here. An aggressive well built H/C/I C5Z can take down a stock or MILD modded C6Z.
breze84
08-14-2012, 11:53 PM
If its a 2000 C5 then why in the video does it have a C5 Z06 gauge cluster???? Pretty gay if he changed the cluster lmao
AZNastyz06
08-15-2012, 11:06 PM
Takes a lot to do for sure. Average C6 Z06 is 450 rwhp. Gearing in Trans is a difference. I have a 540 rwhp C6 Z06 and i don't see a lot that will be able to keep up with that.
venom ws7
08-16-2012, 06:02 AM
He had a problem with his stock cluster and also wanted 6500rpm red line found this for a great price too I guess that makes him gay..
venom ws7
08-16-2012, 06:03 AM
Fixed. ;)
That was my mistake Gary :D
vetteboy2k
08-20-2012, 07:26 AM
I agree with that. Three of my friends have done it many times in great conditions.
And don't forget that both an aggressive well built c5Z H/C/I and bolt-on C6Z have run 9's.
scramblerman
08-23-2012, 04:27 PM
If u are going to buy a c5z06 and then mod the Hell out of it, why not just buy a c6z and be done with it. Not knocking a c5z. Why buy a $25,000 car and put in maybe $10,000 just to run with a stock c6z? Pay a little more and get a c6z instead.
breze84
08-26-2012, 10:38 AM
Yes it does
TransAmcoupe98
08-26-2012, 10:49 AM
If you put 10k in a c5z and cant beat the piss out of a C6Z, then you need to get another hobby. Blower, headers, clutch, CAI, stock cam. 9000 bucks with tune and around 600whp.
scramblerman
08-26-2012, 01:01 PM
U must get a helluva deal on parts prices :nod: I easily have over $10,000 in parts not including all the little stuff, that adds up, not including tires. Plus who knows if the OP can install the stuff himself.
My buddy has a procharger on his C5Z, on 8 psi he laid down 540rwhp on a mustang dyno with full exhuast, stock cam, twin disk. He has a good amount of money in the car. Definitely a badass car!
What I was trying to say is ur are going to have mod the C5Z pretty good to take down a good running stock or slightly modded C6Z, period. The C6Z stock or a modded up C5Z, his choice. Either way he can't go wrong.
Larry
08-27-2012, 02:20 PM
LS3 with a cam and bolt ons.I've beat a few Z06s with my LS3 with just bolt ons! Most don't really know how to launch with the manual tranny.
ysb02
08-27-2012, 03:25 PM
Motor-wise the c6 has a nearly $14k motor also. It seems easy to push to 550-600rwhp with H/C/I/E but if you do something wrong you will be out-of-pocket $10k+ easily. Slap a t-trim or D1 on the c5 and you can get 700rwhp out of it with a much cheaper motor.
jbs02somws6
08-31-2012, 12:28 PM
I had a bolt-on 03 z06 that made 385whp and I now have a c6z with a cai and a borla stinger catback. I agree with Gary2004z06 that a bolt-on c5z on a tire can hang with a stock c6z on a tire in the 1/4 ONLY. The reason is simple, the c6z is much softer coming out of the hole vs the c5z. It doesn't really even hit it's tq band until almost 20mph. The short gearing in the c5z trans is why times between a bolt-on c5z and stock c6z are or can be similar. From a roll, a c5z wilth bolt-on's or will not have a chance with equal drivers.
