Generation IV Internal Engine - na ls7 build... is sleeving needed
baggins
07-09-2012, 08:32 PM
So I have a standard bore ls7 that I just picked up. Its got some mystery flat top pistons, lunati pro billet rods, and a lunati crank. My question is is it necessary to re sleeve the block? I plan on maybe running g a 200-250 shot. This is a street driven six speed car.
Thanks for any input
redtan
07-10-2012, 08:12 AM
Not unless the pistons you have are a much bigger size than can be accepted by the current bore.
baggins
07-10-2012, 09:23 AM
Pistons are 4.125... ill post pics later
ERL Performance
07-10-2012, 09:50 AM
Not saying for sure that you can't do it without sleeving but I have quite a few LS7 cores here with cracked cylinders due to higher cylinder pressure and OEM cast iron sleeves.
Those sleeves were not designed for a 200 to 250 shot of nitrous. I know people will think I'm biased because we sleeve but I thought I would respond to this because I see way to many cracked blocks because of this.
Good luck with your build!
ramairws6
07-10-2012, 09:54 AM
I would agree 100% but thats just IMO and i'm sure we'll hear otherwise...
Reckless
07-10-2012, 10:04 AM
Agree with ERL. I would not push a stock LS7 past about 750 flywheel
87silverbullet
I'm with ERL. The sleeves are prone to cracking. If it was just N/A I would leave it. With the spray I say sleeve it
djfury05
07-10-2012, 10:42 AM
I don't like hearing this since I was planning 150-200 shot :(
6D9 Matt
07-10-2012, 11:52 AM
NA you should be fine, but yes I would recommend resleeving with any kind of nitrous/blower/turbo.
COPO9560
07-10-2012, 11:56 AM
Building an LS7 based engine is not cheap - why cut corners now. If you can afford new dry sleeves, it would provide a lot of insurance for the future. Last thing you want is to have to build this engine twice.
baggins
07-10-2012, 09:13 PM
So I bought a disassembled ls7 shortblock below are the pictures of the pistons. I am having a hard time getting info on brand and specs. The numbers on the skirt are
809ts & 28583
http://i51.photobucket.com/albums/f400/nicktomstew/20120710_172120.jpg
http://i51.photobucket.com/albums/f400/nicktomstew/20120710_172156.jpg
Thanks, Nick
Shelby7
07-10-2012, 09:19 PM
Darton Wet sleeve it and have some piece of mind.
baggins
07-10-2012, 09:38 PM
Not interested in putting $3k into this block.... if I stay NA will I have any issues
delphigto
07-11-2012, 12:45 AM
You could sell the ls7 block and buy a resleeved one for close to the same money and have a better block.
baggins
07-11-2012, 05:09 AM
Whats an ls7 block worth?
ramairws6
07-11-2012, 07:16 AM
^^^ What he said....
ss454327
07-11-2012, 08:13 AM
TSP sells the LS7 block for $2899.
djfury05
07-11-2012, 09:25 AM
how bout a used LS7 block what's that worth?
baggins
07-11-2012, 09:29 AM
Any ideas on the pistons?
MrEracer
07-11-2012, 08:31 PM
They look like Diamond pistons. I'll give you $1000 for your block.
MrE
djfury05
07-11-2012, 10:28 PM
MrE
really... :eyes: Texas-speed lists LS1 blocks at $1100...
baggins
07-11-2012, 10:48 PM
Pistons are custom diamonds for etp ls7 heads.... and nice lowball on the block
Steve - Race Eng
07-12-2012, 12:29 AM
Well, I have three cracked LS7 blocks here to repair at the moment. Any detonation at all will crack a sleeve and block. I have had shops send me cracked blocks from engines just getting a dyno tune to squeeze a bit more power out of the engine.
It is a lot cheaper to sleeve the block prior to the build than to build the engine twice.
Steve
5w20
07-12-2012, 01:46 PM
I would take RED's and ERL's advice.
baggins
07-12-2012, 02:10 PM
I'm selling the ls7 block and gonna run a iron 408
87silverbullet
07-12-2012, 04:06 PM
Man, you don't have to go to that extreme. Just get a used ls2 or alum 5.3 block and let ERL or RED sleeve it. Then you have the best of 3 worlds. Bore of an LS7 and larger, strength damn near the LSX block, and the light weight of any aluminum block.
The price is probably close to what you would sell the LS7 for.
baggins
07-12-2012, 04:48 PM
To what extreme??? Wouldn't that be more extreme than using a 6.0 iron block I already have? Sleeving runs $2k++ . Although I do have a aluminum 5.3 block I use for mock up:-)
87silverbullet
07-13-2012, 08:23 AM
The extreme of using an iron block that will add 110lbs of weight. Plus, on a boosted or nitrous application 4.030 is recommended and 4.080 on a N/A application on an iron block.
At least if you sell the LS7 block you can damn near get the money needed to sleeve a block thru ERL. The sleeves they use are the strongest in the business and you get the bore of a LS7 and larger. Included in that price are the main studs from ARP
http://erlperformance.com/gm-ls-dry-sleeve-block-sleeved
My next setup will be an ERL superdeck 6 bolt.
Jimbo1367
07-13-2012, 04:55 PM
I don't want to be a dick and ONLY offer $1.oo more..... So ....$1001.50:)
87silverbullet
07-13-2012, 04:59 PM
Don't have to be a dick, it was just a dick move by the other guy.
COPO9560
07-13-2012, 06:25 PM
Dry sleeves for the LS7 block would cost you more than the iron 408 but you have many more head options with 4.125 bore if you are looking for big power. Did you buy an entire LS7 or only short block?
baggins
07-15-2012, 08:41 AM
Shortblock only
87silverbullet
07-15-2012, 09:15 AM
Were just saying to stay with the 4.125 bore because it opens up even more head options instead of going with the iron block which your max bore that would be safe in my book would be 4.070-4.080.
speedsdaname
07-16-2012, 04:32 PM
A while back I built a stock ls7 for my 02 Camaro SS,LE with auto trans first
time on dyno with a week auto it made 460 + wrhp.So for a street car with the right cam it should be a hand full.
KCS
07-16-2012, 05:06 PM
Steve
In one of those blocks you have, the sleeve actually failed before the piston did. Aside from a little pitting, it was virtually intact.
slowlaneblues06
07-24-2012, 12:58 PM
I am getting started on a resleeved block project, and interested in using the ls7. PM me a price please.
Roarin_8
07-24-2012, 01:56 PM
You sure about that? I'm seeing 6,xxx for the short block and 10,xxx for the long block for the LS7.
http://www.texas-speed.com/c-107-427-441-cid-ls7-shortlong-blocks.aspx
Never mind, found the LS7 block only for 2899 on the site.
http://www.texas-speed.com/c-123-engine-blocks.aspx
8ty8 LS1
07-24-2012, 03:26 PM
yeah that's what sdparts is selling it for too...OP, please PM me if you want to sell that block.
