chevy9s9s
07-09-2012, 09:14 PM
Hello, im having an issue with my clutch and I have looked all over the interweb with no specific avail. Symptoms occur mainly from stopped N->1st half engagement causes loud grinding noise. I tested second with nothing as much as an underbogging. Reverse seems fine. Clutch fluid is dark after a couple weeks replacement. If u need more info let me know.
JeremyF
07-11-2012, 08:46 PM
Hey there are a few things out there to check out. First thing is I wrote a thread about clutch issues. There are all sorts of issues that can stem from the hydraulic system having one problem or another but this if done thoroughly should for the most part remedy it.
http://ls1tech.com/forums/manual-transmission/1513422-how-prolong-life-your-clutch.html
Hope this helps. It has on every car that we have done.
Jeremy Formato
