Getting a strange "dieseling" effect when I shut off my car.
Old 07-09-2012, 09:33 PM
Bobsmyuncle's Avatar
Default Getting a strange "dieseling" effect when I shut off my car.
Stock computer, stock coils, br7ef plugs, front mount turbo, ect
When I go to shut it off(just idling) it has a small sputter and halfway runs for a second when I shut the key off.
Didn't do it n/a, all the same electronics, car is untuned but I don't think that would make a difference, it should kill it w the switch no matter what. Seems like maybe an electrical issue bc the gauges kinda bounce when I shut it off. Like when the battery goes low
Old 07-09-2012, 09:44 PM
blackmagicturbo's Avatar
is it runnng rich? , do you have a wide band ? it could be getting hot spots in the head, then when you shut it off the vapors from the fuel could be igniting ?
Old 07-09-2012, 10:00 PM
I don't think it's rich, wide band is in it but haven't put the bung or sensor in. I thought about the same thing, but I don't see how it has hot spots when the motor is at like 120* and it's just idling. Atleast I hope it wouldn't lol. I checked all the injector plugs and coils, everything seams fine.
Possibly be the crank or cam sensor? Both worked when I pulled em out of the old motor.
Could it have anything to do w the pushrod length??
Just tryin to spark somethin up here
Old 07-09-2012, 10:43 PM
im not sure , how many turns did it take to tighten the rocker once you touch the lifter till its torqued ?
Old 07-09-2012, 10:59 PM
I checked it w a pushrod length tool, and it came to 7.400" I think so atleast, I did read somewhere that a vacuum leak will possibly do it??
Old 07-09-2012, 11:05 PM
9sectruck's Avatar
try unhooking the alternator power wire that goes to the battery and the single wire, the alternator could be back charging the car. just throwing it out there
Old 07-09-2012, 11:11 PM
do the alternators have a capacitor or something cause my kill switch was off which kills my battery and alternator wire and when i was working on it the wrench arced on the alternator then i checked it with a volt meter and nothing , it was weird ..
Old 07-10-2012, 12:03 AM
Describe "back charging" like charginuntill the aLt stops spinning?
Old 07-10-2012, 12:09 AM
i guess pull the wire and see if it still does it ,, cant hurt , and maybe charge your battery after you shut it off ,, i hope you find it ,its killin me lol
Old 07-10-2012, 12:19 AM
Emdmechanic's Avatar
Electric fans? Depending on the fan and how its wired I have seen them backfeed while spinning down. I know you said everything is the same. Its just a thought. When you say kill switch do you mean a battery disconnect?
Old 07-10-2012, 08:11 AM
It has electric fans, they're wired thru the factory harness, so I figured that'd be fine. Although, they are push/pull, so they might have the effect on it. I will have to check, but I'm pretty sure it does it even when the fans are off.
Although it could be doing it bc of the trans cooler fan too.
Old 07-10-2012, 09:23 AM
9sectruck's Avatar
Basically yes, when you turn ignition off the lil wire that plugs into side of the alternator kills the diods which turns the magnets of inside, which should kill any power trying to be put out by the alt.
My dad had a old truck that use to diesel forever, like to the point we had to pull the coil wire to kill the truck.
Old 07-10-2012, 10:40 AM
So the problem lies somewhere else if this Is the case, bc that wire should quit when the key is switched off. so might be the fans or the trans fan, I will have to unhook one at a time and see what it does
Old 07-10-2012, 10:50 AM
Pathological Modifier
Ryan K's Avatar
Leaking fuel injector.
Old 07-10-2012, 08:14 PM
Unhooked the trans fan, doesn't diesel.
Old 07-11-2012, 08:52 AM
9sectruck's Avatar
good deal glad you got it fixed
Old 07-11-2012, 10:30 AM
Awesome !
Quick Reply: Getting a strange "dieseling" effect when I shut off my car.
