Over flow tank questions
Old 07-09-2012, 11:27 PM
bakomack's Avatar
Default Over flow tank questions
When using an aftermarket over flow is there a particular style that is better than the rest? Do they need to be pressurized or can they be the aluminum cylinder shape ones from eBay?
I need an over flow tank and something small like the cylinder shaped ones.
Is there a style or particular kind that works better than others?
Old 07-10-2012, 12:00 AM
the_merv's Avatar
Overflow for the Radiator? Depends on how you have it setup to be pressurized, or not to be.
Old 07-10-2012, 06:16 PM
FastKat's Avatar
If your radiator already has a radiator cap on it, than you should not need a pressurized overflow tank. If your radiator does not have a cap on it, and there's no other cap on the system, than your overflow tank (now called a "surge tank") will be pressurized and does need a cap.
Old 07-10-2012, 06:34 PM
bakomack's Avatar
I'm using a F body radiator which has a cap so I can use one of the cheap aluminum cylinder shaped ones?
Old 07-10-2012, 07:33 PM
the_merv's Avatar
Should be able too, just install it and plumb it correctly.
Old 07-10-2012, 11:41 PM
bakomack's Avatar
I didn't know there was a wrong way to plumb it.
You just run line to the cap of the overflow container, run the hose through the cap to the bottom of the over flow container right?
Old 07-11-2012, 03:34 AM
the_merv's Avatar
That will work, I meant from the Radiator.
Old 07-11-2012, 09:01 AM
JIMB's Avatar
Speedway Motors sells a nice stainlees steel tank thats actually a recovery / overflow. Not just over flow.
Quick Reply: Over flow tank questions
